optima red top
which optima red top battery is best for our application?
I am using the Optima battery red34- top terminal only, Optima #8002-0020 (34-980). I don't need the extra side terminals.
Advance Auto Parts has it for $118.00. Their part no. is 16080022 Their is also a height adapter 242-0018 that Optima will send to you if you need to keep in higher in your stock battery box. I took the black plastic battery box out since Optimas dont leak. Makes for a very clean installation. Photos in my 96 Polo folder in my locker HERE
The red top I have has both top and side terminals, and I kept the battery box in, got a couple of height adjusters from WallyWorld for free, but have thought about removing the battery box in which case wouldn't need the adjusters, just a different "hold-down"
1992 Liquid Silver LS-L (Sold-5/16/13) 1997 Spruce Pearl Outback (Sold) 2006 B9 Tribeca |
I also have the top and side terminal red top..I simply cut a portion of the battery cover out for the cables to fit properly...at the time I didnt think of the height adjusters..turned out good anyways..
mount
what tie down did you get ... will any fit. i like the look real clean
I used the stock tie-down (had it aluminum ceramic coated). I just threaded the j-bolts down a little further.
Put the battery in without the box, put the stock hold down in place and see how much you have to cut off of the bolts to allow just enough to thread on any wingnuts, bolts, etc. I used chrome, knurled air cleaner knobs on mine. 1/4=x20.
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 05-08-2005 at 01:28 PM. |
