Old 04-01-2010, 09:30 PM
Subie59's Avatar
Subie59 Subie59 is offline
94 SVX LSI Teal
rough idle, low power
Need some suggestions here.
Background: Check engine light on. Then car would not start. Got it going by holding pedal down and cranking until it started. Ran rough for a minute or two and then it was fine.
Took it to local garage: They replaced the temp. control sensor. Still would not start. Replaced the plugs. Now it starts no problem but idles rough and runs rough.
Today I noticed it really does not have the acceleration it used to have and lacks overall power. Runs rough.
I am taking it to Subaru mechanic next week for proper diagnosis but i thought someone here may have exprienced a similar problem.
Thanks
94 SVX LSI
2001 LegacyGT (daughter's ride now)
2005 Legacy outback XT (wife's car)
all stock and likely staying that way for now
1981 Datsun 280zxturbo summer toy
Old 04-01-2010, 11:00 PM
Re: rough idle, low power
Thanks
Presuming the check engine light is still illuminated, --- to get a "proper diagnosis", you should best search here, and then do it yourself for free.
Old 04-01-2010, 11:05 PM
Subie59's Avatar
94 SVX LSI Teal
Problem is check engine light is not on. And I'm no mechanic...
94 SVX LSI
Old 04-01-2010, 11:53 PM
I had similar problem. My light was for Code 56, EGR . I reset the code, the light went off, and the car is acting normally again. Pulling the code and resetting it was very simple.
I have only had my svx for about 3 weeks now, so when I tell you that pulling and clearing the codes on it is very simple, I mean VERY simple.
I had a harder time getting the kick panel trim back on than I did with anything else. It was a pain to line up the push rivet things...
You should always pull codes before taking it to a repair shop. If you know what is wrong before hand, you can find out what it would cost to fix it, so you know if your getting raped at the stealership. Plus they wont be able to lie to you and say its throwing some major code when you know the code yourself.
See the attached .pdf file for the how to with pictures and code list.
(Thanks to original poster of this how to)
Old 04-21-2010, 09:36 PM
Subie59's Avatar
94 SVX LSI Teal
Just a final followup with the problem. Turned out it was a bad coil. Subaru replaced the coil and it is running fantastic.... man I love this car...
94 SVX LSI
Old 04-21-2010, 10:38 PM
One bad coil would not have stopped it from starting.
Old 04-21-2010, 10:59 PM
N.B. and comprehend --- Post #1 “Now it starts no problem but idles rough and runs rough.”
Old 04-22-2010, 04:02 PM
Quote the whole post,
Old 04-22-2010, 05:35 PM
Thanks
N.B. Harvey.
Done. --- For the benefit of anyone else who can not read and is unable to comprehend the written word.
