Old 08-26-2009, 09:52 PM
elemgee elemgee is offline
Noise When Making a Left Hand Turn
When i make a fairly sharp left hand turn at speed, I hear this dragging noise, kind of hard to describe, coming from the rear of the car. Its not real loud. It only happens when I'm making a left at speed, and it doesnt happen all the time, maybe 75% of the time. There's no sound when going straight or making a right hand turn. I checked the rear brake dust shields and they look OK (not that I'd know what I'm looking for). It just started maybe a couple of months ago and doesnt sound like its getting any worse. The pads and rotors are maybe a year old (rotors are slotted and vented). Other than the sound, the car rides fine. Any ideas what this might be? Thanks.
Larry
Old 08-26-2009, 11:55 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Re: Noise When Making a Left Hand Turn
Larry
Jack up the back and check for play in your bearing or hub assy. Then double check your rear pad thickness, sometimes the calipers can stick and wear the pad down to metal on one side.
Old 08-28-2009, 11:06 PM
Thanks Chris, I'll give that a try.
Larry
Old 08-28-2009, 11:29 PM
oab_au oab_au is offline
Check the plastic lining inside the back guard. It may have come away from the edge to rub on the tyre.
One Arm Bloke.
Tell it like it is!
