fixing body rust on an SVX...
Well, I must be the only person with an SVX that has body rust. :-( I just picked up an SVX from the PA area over the weekend, and when I got home and started washing the car, I found some body rust in the crease line on both the doors! So now I'm wondering how I should deal with it. The two options that readily come to mind are to either replace the doors (probably horribly expensive) or try to repair the damaged areas. Any thoughts from people?
I have rust too.
Which crease are you talking about? Where the lower panel attaches to the door? The best way to fix rust (surface only, not holes) is to sandblast the area until all rust is gone, tap it down slightly with a pick hammer, coat it well with epoxy primer, fill divits with filler or good primer if mild enough, then seal it with another coat of epoxy, then paint. Post a close up of the spots and I can tell you what the best way to deal with it is. Doug
Yes, its in the crease area where the lower panel contacts contacts the door. On both doors there is a section about 1.5 inches in length where the paint is bubbling up in the crease. I'll post some pictures in my locker this evening. (Digital cameras are great!) Thanks!
Re: fixing body rust on an SVX...
That's really weird. I would bet that theres quite a bit more rust under that cladding.
Mike |
Glad to see you got the car OK. How was your stay in Pittsburgh? Sorry I couldnt meet up with you.
Mike |
Gettysburg is a really great place to tour. Especially at this time of year. Lots of interesting history there. Mike |
That's really weird. But I suspect that the car has been repainted - if I remember correctly, Laguna Blue wasn't a metallic color.
Anybody?
It is a metallic color... it's actually called 'laguna pearl'
Mike |
