Go Back   The Subaru SVX World Network > Regional SVX Forum & Clubs > European Forum
Old 07-16-2008, 07:54 AM
Nobody Nobody is offline
Send a message via ICQ to Nobody Send a message via MSN to Nobody
A/C gremlins... need advice:)
Hi, for years I am trying to fix my A/C problems with no luck. So maybe some you will have some hints. Joe?
Now it is new filled with no big leakage. Definitely there is some very small leakage as I have to re-fill it every two years but it cannot be found so easy (several times tried with color "coolant" to find weak points with no luck).
So symptoms are:
Compressor switches on and off "randomly" - it seems it works fine at temps around 20-25° but is not so willing to switch on on higher temps. It is strange that even with cold engine it will not start even on N, sometimes switches on on higher revs and during drive.
Revs sensitive - it seems it behaves like revs sensitive - on higher revs mostly working, on lower switching off more often, than switching on, off...
Temperature sensitive - seems while there are really hot days and engine is hot it hardly switches on and if yes, than after while switches off and again. I think there is some sensor which shuts A/C compressor off while engine is being overheated as engine radiator and A/C radiator are in front of each other.
I think it is not caused by A/C control unit as I have spare car and tried to switch them - works the same. It is probably not by any sensor - no error codes after diagnostic. On ECONO mode works fine blowing air according situation (sun, out temp...). Sometimes low revs of vent being on N and increasing with engine revs during drive (old car:-))
So I may assume the problem is at electric or at compressor itself. As I have spare one it is not problem to change current one to spare one but do not want to trial and error method, rather fix it:-)
Thanx for any idea.
Petr
Petr
"It is never bad enough, it could always be worse"
Old 07-16-2008, 08:08 AM
Re: A/C gremlins... need advice:)
Possiably a flakey pressure sensor in the line, or just a bad connection at that sensor (I think it is located in the line up by the radiator on the right side)
Old 07-16-2008, 08:41 AM
Hi, thanx huck. Is this sensor part of A/C diagnostics path? Or shall be checked separatelly? A/C diagnostics show no error codes.
Petr
Petr
Old 07-16-2008, 11:25 AM
Petr
I think you check it seperately....
And like Dave said, if the Freon is to full, it will cause it to shut off, and run off and on...
Old 07-16-2008, 11:35 AM
Hope it is/was checked but can double check. My Subaru dealer does the work for me so I belive they know what they are doing. So far for 5 yrs I own this car they worked for me perfectly, mechanic is fair guy who is not the replacer but rather problem solver.
Thanx both for hints!
Petr
Petr
Old 07-16-2008, 08:57 AM
Hocrest's Avatar
Hocrest Hocrest is offline
Freezepop's are Awesome!!!!
Have you had the pressures checked? If the pressure is too high it can cause it to run intermittently.
