Help troubleshooting headlight problem.
1.) 1996, SVX Lsi, 96,000 Miles, USDM
2.) Modifications that could in any way be related to the issue. NONE 3.) My Left Front Low beam Headlight has stopped working. All other lights work fine. I was hit by a deer recently and the Left outside mirror was torn off, but all lights worked normally immediately following the incident. 4.) Report any environmental circumstances accompany the problem (e.g. only happens when it is raining.) NA 5.) Detail the current state of troubleshooting (i.e. Exactly what has already been attempted in an effort to fix the issue.) Checked Fuses, relays, and bulb. FUSE is OK, RELAY is OK, BULB is OK. I even swapped them out to be sure. 6.) Use your eyes and ears. Report all sounds, warning lights, and associated malfunction that accompany the problem. NA 7.) Advise level of technical experience - No use telling someone that a specific pulsoid or check valve may be involved, if they do not have a grasp of technical terms. I am quite familiar with the SVX as I have driven one since 1994. This one is My 7th SVX and I have a complete set of Factory Shop Manuals.
Reptile Wisdom, Kinglizard |
Re: Help troubleshooting headlight problem.
Almost has to be a bad wire or connector, from the sound of it...
Bad connector sounds plausible. With all the salt in our area, it happens a lot. I had to solder in my speakers to keep them from randomly disconnecting. I am going to solder in the third O2 sensor as well.
I will be at Maple Lawn Dairy after 7PM tonight. I can bring my DMM and grab some needle probes from work if you want to swing by.
Turns out I won't be there tonight. I might be in the area tomorrow, however.
I sent Trevor his post to research. Trevor replied with a lot of useful information and procedures to follow for a diagnosis. I sent KingLizard a PM with his observations.
I sent Trevor a copy of the USDM electrical manual (FSM) many years ago so he could diagnose many of the electriical problems here. His understanding of the electrical circuitry has always been spot-on and has never failed me. The value of information received from him over the years is priceless, and he still continues to give.
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 11-24-2015 at 09:41 AM. |
Tags |
headlights |
