Old 07-30-2012, 04:54 PM
FM977 FM977 is offline
delete this thread.
sdfgdsssdfgdsssdfgdsssdfgdsssdfgdsssdfgdsssdfgdsss dfgdsssdfgdsssdfgdsssdfgdsssdfgdsssdfgdsssdfgdsssd fgdsssdfgdsssdfgdsssdfgdsssdfgdsssdfgdsssdfgdsssdf gdsssdfgdsssdfgdsssdfgdss
Old 07-30-2012, 07:34 PM
Uncamitzi's Avatar
Uncamitzi Uncamitzi is offline
Member #447
Send a message via MSN to Uncamitzi Send a message via Yahoo to Uncamitzi Send a message via Skype™ to Uncamitzi
Re: Fuel pump not getting power
Originally Posted by FM977 View Post
Hello, I'm new here and just bought my svx . Recently, the fuel pump quit powering on. I replaced the fuel pump but still can't hear it run.
I removed the trim from the trunk and checked the wires to the modulator and resistor. All looks good.
All fuses in both fuse boxes look good.
The relay under the steering wheel clicks, but I'm not sure if it's good or bad.
I've tested the wires at the pump and at the relay.
At the pump itself, 6 volts at the yellow and 12 volts at the green next to the black. The rest were dead. All dead with the key off.
At the relay connector, yellow tests hot with the key on, dead with the key off and all the rest are dead with the key off. With the key on, 2 wires (red and green) show negative voltage.
I've also had an issue with duty solenoid c code flashing. I replaced the solenoid, but that issue didn't get fixed either. Seems like some weird electrical stuff going on here.
I'd appreciate any help.
I assume you checked the flow at the fuel filter.
In 12 years of driving this car I don't think I ever HEARD the fuel pump. but then again I may not be listening. What are the symptoms...? I ask because I recently had some starting issues that turned out to be a cam angle sensor that had me checking the fuel pump also.
Mitch Hansen
"uncamitzi"
This is a Dark Ride
92 Teal SVX LS-L 128K tranny swap with 4.11's
Well.. my days of not taking you seriously have certainly come to a middle .
Old 07-30-2012, 07:59 PM
sdfgdsssdfgdsssdfgdsssdfgdsssdfgdsssdfgdsssdfgdsss dfgdsssdfgdsssdfgdsssdfgdsssdfgdsssdfgdsssdfgdsssd fgdsssdfgdsssdfgdsssdfgdsssdfgdsssdfgdsssdfgdsssdf gdsssdfgdsssdfgdsssdfgdsssdfgdsssdfgdsssdfgdss
Old 07-30-2012, 08:14 PM
I disconnected the in line to the filter and there is no fuel flowing through the hose.
Does anyone know where the ground wire is to the fuel pump? Is it under the passenger back seat like on legacies?
Old 07-30-2012, 11:24 PM
Uncamitzi's Avatar
Member #447
Not sure...but this sounds familiar ..here's a link to another thread.. Might have some better info for you.
View Post http://www.subaru-svx.net/forum/atta...7&d=1342909427
Mitch Hansen
"uncamitzi"
This is a Dark Ride
Old 07-31-2012, 12:59 AM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
Is there an alarm or immobiliser system that cuts power to the fuel pump?
Any codes from the ECU?
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
Old 07-31-2012, 03:03 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Did you maybe replace the filter recently? Maybe the lines were mixed. Try switching the feed and return lines going to the engine.
Subaru SVX for fun
Susuki SX4 for my older son
Ford Ranger for work
Old 07-31-2012, 06:59 PM
Old 07-31-2012, 10:26 PM
Uncamitzi's Avatar
Member #447
Uncamitzi, thanks for the reference but the link was dead. Were any characters left out?
I have not replaced the fuel filter recently.
As far as I know there's no immobilizer system that shuts off power to the fuel pump.
I have also been getting code 21 for duty solenoid C before the fuel pump quit.
http://www.subaru-svx.net/forum/showthread.php?t=55512
try that one.... I'm a bit rusty at this...
Mitch Hansen
"uncamitzi"
This is a Dark Ride
Old 08-04-2012, 03:42 PM
Old 08-04-2012, 04:18 PM
It's pretty bad that this happened. Subaru should have done a better job designing that connector so things like this don't happen.
There is more than likely some other underlying problem to cause that.
Clearly an electrical connector getting a little hot after 20 years must be the manufacturer's fault.
Old 08-04-2012, 04:32 PM
Yes, clearly it is.
