Looking for part numbers
I'm looking to confirm the part numbers for the following:
- R134 A/C sticker for the top radiator mount - Evaporator sensor (to fix my code 14) - 2 clips to hold the plastic "side garnish" on. (The 2 that are hidden by the front of the door by the hinges)
No one knows?
The only R134A AC label I can find is 73090PA030
The 2 screws for the garnish should be 91017PA210 I know the sensor that gives you a code 14 (shorted intake sensor), is installed on the evaporator assembly case (See FSM Section 4-7, pg.20) Since the code says that this sensor is bad and not working anyway, try to pull it and see if there is a PN on it. FSM 4-7, pg. 114-115 gives you instructions on how to check to see if it is the sensor, the harness, or the audio amplifier (which is connected to the rear of the AC control panel) Wish I could be more help. .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 07-27-2006 at 02:18 PM. |
I would pull the sensor except for the fact I would need to remove the evaporator assembly and that would require evacuating the system. I would rather have a replacement sensor for when I get that done. There are 2 sensors on the evaporator but no diagram on subaruparts.com so I don't know which one is which. As for the A/C label I found 2. One is the one you mentioned the other ends in 020. I think the 2 screws/clips are different between top and bottom. Maybe I'll take a picture of the 2 I need.
I believe there are 3 parts for the clips needed. I know that one of the clips account for 2 part #'s one is 91059PA040- this is a female end and 91017PA180- this is the male.
