Old 03-29-2005, 05:09 PM
freak customs freak customs is offline
Send a message via ICQ to freak customs Send a message via AIM to freak customs
c/v shaft
has anyone had any trouble removing or installing their c/v shafts?i've replaced the driver's side and it feels like it doesn't want to turn (brake is off as well).
i'm trying to change the pass. side now and i can't seem to get it in all the way so i tried to remove it again (maybe the clip is too stretched) and now it won't come out
any suggestions on either problem? i've NEVER had this much difficulty changing c/v shafts!
Old 03-29-2005, 05:10 PM
immortal_suby's Avatar
Thread Killah
No - they should slide on and off the splines pretty easily.
Locker Link
2015 BRZ Limited 6MT
Old 03-29-2005, 05:18 PM
Earthworm's Avatar
Meow!
Which side is stuck? (tranny or hub)
The reman axle I installed had a seal on it that shouldn't have been there. I didn't realize that until I tried to rotate the wheel and it was tough to turn.
Old 03-29-2005, 05:31 PM
the stuck side is the tranny end on the pass. side... come to think of it, the driver's side had a seal on both ends of it. that may be why that side is very difficult to turn.
Old 03-29-2005, 05:34 PM
what i think got it stuck is the clip on the spindle. i think it may have slipped, wedged, or otherwise broke out of it's place when i slid the spindle into the tranny.
Old 03-29-2005, 06:03 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
Significant Technical Input
You shouldn't need to pull the spline stub from the diff to change an axle. There is a roll pin that secures the axle to the spline stub. Normally one drives the pin out and the axle easily slides off of the splines. Reverse procedure to install.
