ngk Part number
Does any body know what the part number for NGK spark plugs for the SVX
Re: ngk Part number
I should have clarified I need non platnium NGK R plugs one heat range colder than stock
I have those plugs, Kevin. I'll check the numbers and post them by tonight.
Damn, I don't see any number even close to what Aredub posted earlier on the box, and I don't have my invoice with me right now. This is the only info I have:
PFR6B-11 <---- Old platinum stock spark plug BKR7E-11 <---- New non-platinum plug, one heat range colder ^^ PF = Platinum ^ 7 is one heat range colder than 6. That's what I remember, from what my tech told me. And if I had to guess at what you were up to, I'd say nitrous.... I don't remember turbos needing non-platinums. Whatever it's for, good luck. If you need more info, I'll see what I can find. |
Randy Johnson 3rd Registered Member 02-21-2001 First Member to Reach 10,000 Posts First to arrive at the very first Reading Meet Subaru Ambassador 1992 SVX PPG Pace Car Replica 110+k 1993 White Impreza L 240+K miles 2001 Legacy Outback Limited Sedan 250+K miles 2013 Deep Indigo Pearl Legacy 3.6R 49+K miles "Reading is my favorite Holiday" Mike Davis -- at Reading VI Last edited by Aredubjay; 07-28-2001 at 12:23 AM. |
Thanks thats cool the SVX uses the same spark Plugs as my dads 99' RS-T
This is probably why my friend screwed his Merkur up so bad. Or maybe it was the fact we upped the boost from 8lbs for 14.5lbs. One of the two. Ryan
92 LS-L Claret / Black UR Underdrive Pulley, Bosche Platinum +4 Plugs, K&N Cone Filter http://www.ryanmacdonald.com http://www.digitalvertigo.net http://www.open-innovations.com |
