Info required on the Headlight washer option
Hi guys, I'm from New Zealand and wonder if someone can show me how the headlight washer system is setup physically and electrically ?
I know that there must be another pump or washer bottle somewhere in the car, together button on dashboard, extra hoses and the outlet jets on the bumper. We never got that option - but I have spare position on the dash to fit the switch, so wondered how hard it would be to fit. Thanks Steve in Auckland, NZ
1995 LSI, Added the following - Gear Firm-Up unit (that I sell) together with Power TCU ROM & Power switch, K&N air filter, SVX side badges (USA type), Rear Deck Blower (JDM type), Side front markers (USA type), Side rear markers (USA type), Middle rear light (USA type), USA OEM Fog Lights fitted into NZ OEM glass (NZ OEM headlights had only reflectors fitted) Full set of yellow (90SH) Polish bushes includes 15 min mod, R1 Concepts drilled/slotted/gold finish rotors & Red covered braided brake lines (both from Dayle at Motorsport warehouse), EBC Redstuff brake pads. Full SVX bra (only used for shows). Koni adjustable inserts fitted inside OEM strut body, Zoom lowering springs (2" lower), OEM headlight washers fitted. Last edited by SURTEESS; 04-04-2016 at 03:53 PM. |
Re: Info required on the Headlight washer option
come on someone must have exploded picture or some photos etc so that I can piece together where things go ?.
On the XT6, the headlight squirter shared the windshield washer tank, just a separate pump at the bottom for the headlight squirters.... The Headlight Squirters wasn't an option here in the USA so I'm not much help.....
Huck,
thanks for the update, may take out the washer bottle later & see if there is a blank area that a second pump could fit into.
I'll follow your progress on this mod....
Steve, I can confirm that there is an extra water bottle/reservoir that fits inside the inner wing, the pump is in this extra bottle. I have a complete spare set up from a Polish (European) car, jets, hoses, both bottles and dash switch.
Mal |
Mal - PM sent to you.
steve, cant you find the info on a nz new svx with light washers fitted as standard?
Carl,
I have been to Subaru to look at their workshop manuals - since they do not show anything about the headlight washer system I take it to mean that no NZ new ones were supplied with that option. (I also checked out the fog-light option - that was also missing, which is right as NZ did not get that option as an OEM). I will wait till someone pulls one out of a car to let me know where the 3rd tube goes.
Although the US didn't get the headlight option, the inner momentary switch on the right side of the dash, is the switch for the headlight washer but it doesn't have a symbol. I had inquired on the forum, years ago, bout installing the system and a member said he had instructions but I never pursued the idea. I'll check my threads to see if I can find his identity.
Not really worried as to where the interior switch is located, as in NZ we also did not get the wiring harness...there were 3 switch positions that are blank when it arrived in NZ, also the OEM switch mechanism has neither the contacts moulded into then, nor any lighting recess areas - I bought various switch assemblies from ebay to get 3 switches on each side - then moved either covers or wiring pins to match what main wiring harness mates within the cars original wiring loom.
The 3rd tube in the picture is actually just a vent, it needs to be placed next to the top bottle - sort of an overflow. Thanks again.
1995 LSI, Added the following - Gear Firm-Up unit (that I sell) together with Power TCU ROM & Power switch, K&N air filter, SVX side badges (USA type), Rear Deck Blower (JDM type), Side front markers (USA type), Side rear markers (USA type), Middle rear light (USA type), USA OEM Fog Lights fitted into NZ OEM glass (NZ OEM headlights had only reflectors fitted) Full set of yellow (90SH) Polish bushes includes 15 min mod, R1 Concepts drilled/slotted/gold finish rotors & Red covered braided brake lines (both from Dayle at Motorsport warehouse), EBC Redstuff brake pads. Full SVX bra (only used for shows). Koni adjustable inserts fitted inside OEM strut body, Zoom lowering springs (2" lower), OEM headlight washers fitted. Last edited by SURTEESS; 05-11-2016 at 05:34 PM. |
