Old 01-06-2003, 02:42 PM
Seraph's Avatar
Seraph Seraph is offline
I abuse them one at a time
Which fuse
Which fuse controls the warning lights? I blew a fuse and now non of the warning lights are coming on. Anyone?
Lwin
Lwin M. Maung (Member # 147)
Current SVX: NONE
Old 01-06-2003, 02:49 PM
Boone
There's a 15a fuse marked "hazard" in the underhood fuse box. Is that what you mean? B.
Aredubjay's Avatar
Rat Fink Member ~:o)
Re: Which fuse
Lwin
Fuse #15 is listed as controlling the "Meter." I don't know if that means the "Combination Meter" or not. #9 is listed as "Illumination brightness control." #27 is listed as the "Lighting Switch" fuse. I'd start by checking #15. There are none, specifically that are assigned to the "Warning Lights" (which I expect you mean the ATF/POWER/AIR BAG etc, lights).
Randy Johnson
Mike Davis -- at Reading VI
Old 01-06-2003, 02:52 PM
Aredubjay's Avatar
That would be fuse #28.
9 and 15 are in the kickpanel box, while 27 is in the underhood box. FYI.
Randy Johnson
Old 01-06-2003, 04:26 PM
Seraph's Avatar
I checked all those fuses. All working. I will check them again tomorrow. Got too cold all of a sudden. Can't work in the parking lot if it gets too cold.
Time to buy a house. Time to find a job first.
L
Current SVX: NONE
Old 01-07-2003, 10:19 AM
Aredubjay's Avatar
L
Perhaps it isn't a fuse at all. Perhaps you've blown a relay. I'll have to check my manuals when I get home to see if there's a relay inline with the combo meter -- although, you probably know more about the combo meter than most people, since you've had it out, and in, and out, and in, and out, and in . . . . . . . .
Randy Johnson
Old 01-07-2003, 10:40 AM
sfsvx's Avatar
sfsvx sfsvx is offline
Yeah, it's a poodle - so what?
Where's the Combo Meter? (I need to measure my combos. )
Dick
1999 Legacy GT 30th Anniversary Edition
2001 Outback Sport
Old 01-07-2003, 12:18 PM
Aredubjay's Avatar
Do you use the pizza flavored, or just the regular cheddar cheese Combos?
Randy Johnson
Old 01-07-2003, 01:42 PM
sfsvx's Avatar
Hee hee
No, really - is the Combination Meter the climate control display? Mine's never worked right and maybe I need to check a fuse or two.
And it's the cheddar cheese.
Dick
2001 Outback Sport
Old 01-07-2003, 01:49 PM
Boone
Re: Hee hee
The climate control thingy is called the "auto amplifier". There is a .pdf that may help in my locker.
Hmm.. pizza flavored for me..
Old 01-07-2003, 02:16 PM
sfsvx's Avatar
Re: Re: Hee hee
Thanks, Boone - I've looked in your locker a few times to figure out what my climate control should be doing.
I was thinking that maybe the temperature display on the auto amplifier was referred to as the combination meter since it shows two different temperatures.
Dick
2001 Outback Sport
Old 01-07-2003, 03:44 PM
Aredubjay's Avatar
Re: Re: Re: Hee hee
The "Combination Meter" is what Subaru calls, what we call "The Instrument Cluster," containing the speedo, tach, etc.
If your display is totally inop, you might check fuse #3. Though it doesn't list it in the manual, it controls the lighter, electriconically heated mirrors AND the climate control unit.
Randy Johnson
Old 01-07-2003, 05:17 PM
sfsvx's Avatar
Re: Re: Re: Re: Hee hee
Well, now I feel dumb.
I'll check the fuse. Thanks, Randy.
Dick
2001 Outback Sport
Old 01-07-2003, 05:34 PM
Boone
If the "auto amp" is TU check fuse #25 (10A) in the underhood box. It's marked "clock" but thats what it says.
Old 01-07-2003, 07:46 PM
Seraph's Avatar
After going through each and every fuse, I found that the last fuse was blown. Great way to start the day. I am currently delaying all electronic related projects for now. I want to find a good dash replacement solution first.
Thanks for all your help with the fuse numbers.
L
Current SVX: NONE
