Old 12-12-2008, 10:38 AM
thewebdevil thewebdevil is offline
Hooked up Jumper cable in reverse
My SVX battery died and someone was going to jump me off but they hooked up the battery cables in reverse and smoke started coming out from under the fuse box under the hood. I put a new battery in but now nothing in the car has power and the battery cables don't even spark when I connect them. I have another old SVX that I can take parts out of. Does anyone know if there is a main fuse that would have burned through or what would have happened to the electrical system when the cables are hooked up in reverse?
Old 12-12-2008, 10:40 AM
Re: Hooked up Jumper cable in reverse
You likely toasted the fusable link but more than likely toasted the entire fuse box.
Old 12-12-2008, 11:41 AM
Where is the fusable link located? I have the entire fuse box out of my spare SVX out that I can use. The smoke was coming from the FWD and AC fuses (and all the wires come into the fuse box from under them.)
Old 12-12-2008, 11:59 AM
if the wires outside of the fuse box are not damaged I would replace the whole box.. Not too hard to do
Old 12-12-2008, 12:49 PM
kwren's Avatar
kwren kwren is offline
fusable link is in the main fuse box recommend testing things. there are other fuses besides main fuse box.
Bummer.
Keith
Old 12-12-2008, 02:51 PM
I checked the fusable link and it was burnt to nothing. I replaced it and everything is working great. Thanks guys!
Old 12-12-2008, 03:18 PM
green_eyed_lady's Avatar
green_eyed_lady green_eyed_lady is offline
Boy, are you lucky! You should play the lottery today!
Diana
1992 Liquid Silver LSL, >230K -- "Silver Bullet" // dimpled/slotted rotors, SS brakes lines, 5000K HID headlights // TRI-TONE paint
Old 12-12-2008, 03:22 PM
Excellent, you dodged a bullet. Glad to hear the fusible link worked. I fried one once changing an alternator with the battery connected. Duh!
