Old 10-20-2008, 12:53 PM
The1One1AndOnly The1One1AndOnly is offline
Where Is The How-To On Valve Cover Gaskets?
Went thru the how to documents and coulden't find any instructions on changing the valve cover gaskets, really need it asap. If u don't have it here and someone has a brief description or a personal manual or link to 1. It be really appreciated thank you.
Old 10-20-2008, 02:30 PM
sabin sabin is offline
Banned
Re: Where Is The How-To On Valve Cover Gaskets?
removed the coil packs and spark plugs. then remove all the bolts on the valve cover.
it helps to remove the battery, air intake, and washer fluid tank
Old 10-20-2008, 05:48 PM
wantafastsvx wantafastsvx is offline
and make sure you got the o-rings that go underneath the cover
Old 10-20-2008, 06:03 PM
Maybe it's not in the "how to's" yet.
Search for a thread started by "redlightningsvx" a few months ago...
edit... Here ya go http://www.subaru-svx.net/forum/showthread.php?t=44396
Old 10-20-2008, 06:09 PM
redlightningsvx's Avatar
Collision Refinishing Tech
It was never added
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 10-20-2008, 06:27 PM
Originally Posted by redlightningsvx View Post
It was never added
It should be, it's a good one...
Earl, Chris???
Old 10-21-2008, 04:00 AM
Wanta and sabin thanks for the advice. And homecrest your alot of help first with the dealer now with the link for the repair. really apreciate it.
redlightning i gotta say.....Very! helpful, thanks alot man and whoever is admin must put that in.
any of u guys need a wholesale electronics connect lemme know ill give u a link that will blow ure mind. Thanks Again.
Old 10-21-2008, 04:01 AM
I ment Hocrest lol***** pardon.
Old 10-21-2008, 09:17 AM
what kinda electronics we talking here?
Old 10-21-2008, 09:40 AM
By the way how many bolts and seals are their all together, i know their are 6 gaskets, and 20 bolts, i believe, and are they all the same size, or different size bolts. And how many seals, and is it important to get them new or should i use the old ones and should i just get the gaskets and seals? or just gaskets?
Old 10-21-2008, 09:44 AM
Go To NewEgg.com its the best online and all electronics and appliances wholesale retailer, i deal electronics and i live in NewYorkCity and im tellin u, u will not get a better price. You can thank me after u see it. Look at the prices their and compare, and make sure u sighn up to the newsletter. You will get extra promo codes and discounts in ure mail and these actually matter. They also have something called shell shocker deals, u will see for yourself, huge wholesale dealer, compare prices and u will freak out.
Anybody who uses my source and like's it, A thanks would be nice.
My hookup to this website, cause so far uve done me justice.
Old 10-21-2008, 05:33 PM
Just buy everything I mention in the first post of the how-to and you'll be set!!!! Also you don't need bolts just the washers. NEVER use old gaskets!!! since your already removing the other gaskets you might as well replace the rest for insurance down the road.
Seth
Past subies:
Other toys:
Old 10-22-2008, 01:26 AM
yeah thanks red......... i ordered it today 6 gaskets, 20 washers a p/s return hose for the other leak and the o-ring. Total with shipping came out 125. ordered it from a dealership 40 miles away so it should hopefully come by fri. will let u know when im done with it, thanks again for the how-to.
Old 10-25-2008, 04:53 AM
red im not exactly sure the whole leak is from the p/s hose, i know the gaskets are leaking but they leak oil. My p/s flued is goin a bottle a day, the leak is comming from the back area by the valve cover gaskets, its leaking hard but dont exactly know, i though the p/s flued can only leak from the hose?, thought i had it all in my and now im confused, any other places where it may be comming from, or is it something i dont see?
Old 10-25-2008, 11:28 AM
Earl, Chris???
I will see what is in the thread and will try to get it in the locker.
