Old 06-24-2008, 10:18 PM
robinhoodof she robinhoodof she is offline
sunroof won't open
My 96 has a sunroof that wont open. No power to the switch. When I jump into a live & put it directly to the switch I then have a signal that both sides of the switch work, but still no action @ the motor. Any quirks on this system? Is there a fuse or a relay ???? & do you have to take the whole roof headliner down to get @ the motor?
Old 06-25-2008, 08:51 AM
ShiuludeSVX's Avatar
Re: sunroof won't open
Sometimes it sounds like mine is not doing anything, but if I Thumb the switch, and use the rest of y fingers to push up on the panel at the same time, it will go up.
This is just the age of the motor, and I expect you can adjust the strength over time. I have not done it myself tho, I just adjust me to fit the needs of the car.
The Worm
_______________
June '91 Claret LSL #1733, Enkei RS-5's x 16", Original Paint, accompanied by Beautifully speckeled Front Bumper, Sony Audio Components, Small Car Shift Kit, "How to" Hood Lifts {Perfect}, "15 Minute Suspension Mod"
Motorsport Floor Mats. Perma-Cool External T. Filter, New Front Axels {1/2008}. "Classic Radiators" unit "$36 coil alternative" and Tranny rebuild at 287k 8/2012
'05 Infinity G35 Coupe.
No Mods, 33K Miles
Old 06-25-2008, 04:11 PM
Keoni's Avatar
Keoni Keoni is offline
yeah try pushing on the sunroof while pressing the button. mine does the same thing, when you press the button nothing happens, you can hear the motor trying. but it wont open unless you help it alittle
Old 06-25-2008, 05:17 PM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
Cool Re: sunroof won't open
Mine did that a few years ago - so spent about 2 hours!! cleaning ALL the rails then spaying a CRC lube into all the places (wipe away excess so that is does not get into head liner or paintwork).
Should get it all going - if not then check the folders area on sunroof adjustment? (I presume that someone might have posted a "how to do" in there?)
Old 06-26-2008, 01:02 PM
Lockleaf Lockleaf is offline
Pretend Innovator
My 92 as well as another one that I have seen acts like that. Can you hear the motor turning at all? If so then like they said, push up on the sunroof. You don't have to do it while you push the button though. Push the button to release the sunroof, then push it up and then push the button again to open it.
5MT - Impreza style, short shifted, TiC/Kartboy/ES Poly stiffened.
Old 06-27-2008, 09:18 PM
Thanks but there's NO power to the switch, guess I'll have to trace...
Old 06-27-2008, 10:01 PM
kwren's Avatar
kwren kwren is offline
This link shows the supply source and component location for the sunroof testing.
Hope it helps,
Keith
http://www.ourlifeline.net/robinhoodof%20she.htm
Old 06-27-2008, 10:27 PM
Check the Overhead {Vanity} Mirror wires.
The Worm
_______________
No Mods, 33K Miles
Old 07-01-2008, 08:25 AM
laserx's Avatar
laserx laserx is offline
For my "sticking" sunroof, I use silicon spray on the "gasket" around the sunroof. I have to do this every couple of years. I too was using the "push it up with your hand" method until I tried the silicon spray. Make sure you give it a good dose, might take two before it stops sticking. Might want to grease the rails while your at it, I use white lithium grease.
1996 Black, 134,000 KM, with Custom Stainless from Headers to Stebro, 17" Wheels, Michelin Pilot Sport PS2 225/45/17 Cold Air Intake.
Pioneer AVIC D3 GPS/Video/Sound/Sirius/Bluetooth/USB
Koni struts/ground control coilovers
Stainless steel brake lines
K&N filter, custom front grill
H.I.D low beams 5000k 35w, H.I.D fog/driving 4500k 35w
Clear front and corner lens
Old 07-02-2008, 11:53 PM
Hope it helps,
Keith
Thanks Keith, where did you get this link? Comes up hard to read ( maybe it's my eye's) LOL...Chris
Hey thanks I will, these in series???...Chris
Old 07-03-2008, 12:20 AM
kwren's Avatar
Sorry, little hard for me as well wasn't a good thing
I will try to make it over need a little time
Keith
Old 07-03-2008, 12:21 AM
kwren's Avatar
series with what????
not connected to sun roof
Old 07-03-2008, 01:13 AM
kwren's Avatar
Re-did it!
try it now may have to refresh the page, not sure
Sorry about that...
Here you go
take care,
Keith
Old 07-03-2008, 10:18 PM
tiv0's Avatar
tiv0 tiv0 is offline
svxless
yes...i agree
Trevor
Avondale, AZ
1992 LS-L Liquid Silver 126k "BXR6" Sold 3/23/13
1992 LS-L Claret 178k totaled 10/26/09
1987 BMW 325is
60% of the time it works, every time
