Old 09-27-2007, 04:11 PM
cruisen_15's Avatar
Question fuel filter
im unsure if the fuel filter is bad or not... is there any way to test if its bad? can a bad one really hurt your engine performance??
Old 09-27-2007, 06:10 PM
Yes, if the car can not get fuel, it won't run very good.
If it has been a while since you have changed it, or if you have never changed it, I would do it.
Old 09-27-2007, 06:21 PM
nexus_7 nexus_7 is offline
dirt cheap...might as well just do it. Just my opinion.
Greg
Old 09-27-2007, 06:28 PM
cruisen_15's Avatar
running bad would be symptoms of hesitation and bad gas mileage??
Old 09-27-2007, 06:36 PM
Hop Hop is offline
Classic SVX
fuel filter how-to?
When I looked at the how-to file for replacing the filter, there were 2 docs. One is what to do before changing the filter and the 2nd is the same as the first. Does anyone have the right doc on how to change the filter?
Old 09-27-2007, 11:48 PM
I would unplug the fuel pump and then take the hoses off and then put the new filter in and put the hoses on. It is very simple and would be hard to mess up. If you waited till the next day to do it, you probably wouldn't even need to unplug the fuel pump. The pressure would already be next to nothing.
