Old 05-30-2007, 07:13 PM
JaySVX's Avatar
JaySVX JaySVX is offline
Move over (so called) SVX Mechanical Experts!
That's right, there's is a new mechanical master on the forums. To display my masterful mechanical skills, I recharged my AC today by my self!!! I challenge any of you to match such sheer ingenuity in auto mechanics. Anyone who doubts this astonishing feat I can prove it! Just come by, those of you with doubts, and I will gladly give you a ride with the cold AC blowing in your face!!!
Generally I can do most mechanical procedures, weather I've done them or not, but I'm completely paranoid unless there's someone around, weather they know what they're doing or not. I second guess myself all the time when working alone, to the point that I can't accomplish anything. Anyways, I didn't charge the AC entirely on my own, called OT, because I've never touched AC before, except for removing it from my old racer, and it said to charge only with the engine running and the AC compressor on, but mine wouldn't kick in with it being completely empty, so I thought i might have to jumper it or something...
*No SVX at the moment...*
1987 Winnebago Elandan 35'
2001 Yamaha Roadstar 1600
Old 05-30-2007, 10:08 PM
Now for the big question before your ego deflates! Will it stay charged, or will it leak out? That is the question.
Old 05-31-2007, 02:29 AM
Originally Posted by JaySVX
Anyways, I didn't charge the AC entirely on my own, called OT, because I've never touched AC before, except for removing it from my old racer, and HEsaid to charge only with the engine running and the AC compressor on,
I hope it stays charged.
cool, get it?
Old 05-31-2007, 03:15 AM
JaySVX's Avatar
If it leaks, i have no idea how to find the leak, but it has been suggested to me that i should replace the o-rings first, apparently they become rotted and such, and are pretty inexpensive to fix.
Old 05-31-2007, 11:47 AM
davew833 davew833 is offline
If you open the system to change the o-rings, you have to evacuate it with a vacuum pump to eliminate moisture or you'll have big problems. Some people recommend replacing the filter/drier whenever the system's opened, too, but I only do that if the compressor's exploded.
davew833@yahoo.com
Former 6-time SVX owner
Old 06-01-2007, 12:50 PM
If it leaks, you will know as within a week most of the freon would have left the system... The dryer replacement is a good idea. Either way, a leak is probobly going to come from the o-rings or a hole in the condensor
Old 06-01-2007, 03:31 PM
Yes, the O-Rings are inexpensive to fix. That may be why it leaked in the first place.
Old 06-01-2007, 10:41 PM
kwren's Avatar
kwren kwren is offline
what "O" rings?
what "O" rings? in the compresor or where?
TX
Old 06-12-2007, 08:31 PM
Every connection in the A/C system has an o-ring to seal it. There's about 13 in total.
Old 06-13-2007, 12:00 AM
SSSVX's Avatar
SSSVX SSSVX is offline
One teal and One yellow
which one did you charge ? did you still have the 92 ? So, about 2 weeks later still ice cold ? Some leaks will take like few, few months to a year. If you have a big leak, maybe in one, two weeks. You could put in a can of "stop leak" oil(usually is 3oz) into the system to prevent any minor leak. A can of R134 freon is usually about 11~13oz.
Just help my friend to charge an SVX yesterday. Learn more every time. =)
-SSSVX
92 LS-L TEAL since Aug '01
92 LS-L YELLOW since Mar '05
