Old 05-29-2007, 10:34 AM
svx_commuter's Avatar
OBDI Scan Tool, Select Monitor Connector MAYBE
I have purchased an OBDII ScanGauge2 for my Astro van. It works good. Has a nice MPG meter and other gauges available for display.
I have looking for something to use on my 1992 SVX but there isn't much of a market for this tool since the SVX is before OBDII.
So I was asking around and got a response from the UltimateSubaruMessageBoard. The link is below.
http://www.graphics.cornell.edu/~v/b10scan/
Now this could be something of interest to few people here.
Shows how to hook up to the select monitor connection using a lap top.
SuperbVehicleXtraordinary
Proud sponsor of a 1992 SVX.
Old 05-29-2007, 10:40 AM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
You need to read this thread:
http://www.subaru-svx.net/forum/showthread.php?t=38685
and my website: http://www.alcyone.org.uk/ssm
Works 100% on my OBD-I 94.
Can't seem to get any sense from the ECU of my the 92 but it works with the TCU.
Phil.
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
Old 05-29-2007, 11:06 AM
There is a lot more detail here.
http://bbs.legacycentral.org/viewtop...=asc&start=325
Old 05-29-2007, 03:09 PM
Nomake Wan's Avatar
Retired
svx_commuter, Vikash indeed had a tool for interfacing with the first-gen Legacy. I still have a copy of it, as well as a laptop (which is currently dead, oh well) to run the DOS-based software on. But it's not very useful for the SVX.
Phil (b3lha) has been working on an SVX version of the tool, which appears to work right in Windows too. And considering Phil's talks to the TCU, cruise computer and climate control... yeah.
Thanks for the link, but progress is already being made in this direction.
Old 05-29-2007, 08:57 PM
nextse7en's Avatar
Graphic Artist
I seem to remember that 93 and up was reprogrammed. Any progress on 92 svxii? Is it possible the legacy method would be more successful on the 92 usdm ecus?
-Patrick.
Also - the legacy software works via parallel port - is there a way to get b3hla's software to accept inputs from that port - rather than serial?
Patrick
6Xk Miles.
[SIGPIC][/SIGPIC]
Old 05-30-2007, 07:55 AM
b3lha's Avatar
Phil & Belha
-Patrick.
As I understand it, Vikash's Legacy software originally used the parallel port, but then he started using the serial port because of problems with the signal timing on the parallel port. The ECU connection is a serial port, so I think it makes sense to connect it to the PC serial port, rather than connecting it to the parallel port and trying to decode the serial signal in software. Having said that, you are welcome to modify my software any way you please.
You are right in saying that I haven't got it working on a 92 yet , but I don't think that any of the available softwares will work either since we are all using the same method of getting the data.
Currently I only know of three softwares available.
* Vikash's Legacy software could be modified to work with the SVX. It's a DOS program written in assembler.
* My software currently only extracts data to a file, it's intended to help me investigate how the control units work rather than for datalogging. It's a Linux program written in C.
* The best software is Kevin Frank's VWRX software. It has a nice Windows GUI and I've written a config file for it that will work with the SVX (you can get this from my website). I've asked Kevin if he'd be willing to give out the source code so we can customise it, but I haven't got a response yet.
