Old 01-31-2007, 12:12 PM
susank susank is offline
Help! SVX power driver's seat bolt dilemma
(I've also posted this on the Yahoo SubaruSVX group.)
The power adjustment for the driver’s seat in my 1992 SVX began to malfunction. It would only go backwards, not forwards. Otherwise, it seemed OK (up, down, etc.). I bought a new wiring harness for the seat. I’ve asked a very reputable shop to install the new harness.
Here’s the problem: Since the seat went all the way back, they can’t access a bolt for the seat. So they can’t replace the wiring harness.
I’ve told them to try to jimmy or wiggle the current harness to get it to move forwards. (It’s worked in the past.)
Any ideas out there? They’ve spent a lot of time (and $$$) on this. I’m getting ready to sell it and obviously the seat has to work!
Thanks so much,
Susan K.
Old 01-31-2007, 12:53 PM
Have them first raise the seat for room to work.
On the right front corner of the drivers seat there is a connection for the f/r movement.
Have your mechanic disconnect the plug, and hot wire it to power the seat forward.
Does your harness include the switch?
It is most likely a bad switch.
Old 01-31-2007, 01:18 PM
Darren's Avatar
Darren Darren is offline
Are sure its the harness if its still got some motion?
Have you checked the runners are clear, the smallest bit of gravel or something can jam them.
I would try WD40 (if you guys have it there, its a lubricant/Cleaner do it all saviours in a can!) Spray it into the switch, it wont do any damage so nothing to lose. It sorted the seat switch on my Lexus SC that used to move & stick all on its own.
Darren.
11/94 SVX Alcyone, Mica Black, VL Spec 4WS, 71K Miles, 1 owner from new & was part of a private car collection in Japan.
Nissan R34 Skyline Stagea
91 Lotus Elan SE Turbo
1966 MGB Roadster, Tarten Red, Wire Wheels, Leather, 23K miles from new
You can tell the men from the boys from the speed of their toys.
