Old 09-24-2006, 01:08 PM
SVXBart SVXBart is offline
how bad is this?
i was working on my noisey breaks and noticed this
how bad is this you think?do i need new hoses?
does the term "SS breake lines"as meany members has on theirs svxs apply to hosese or hard lines?
Bart
Old 09-24-2006, 01:41 PM
gest24's Avatar
$ gest24 $ gest24 is offline
#1 6MT In Cali
You should replace the lines. The SS lines would replace those lines.
Sand Diego SCCA Solo 2 #308
RIP
84 VW Scirocco
02 WRX
Check My New Homepage..
Old 09-24-2006, 09:22 PM
Speedklix's Avatar
Locker Link Solution
yup, that line is going to burst soon!
when it does, the brake fluid is going to spray all over and smoke. You will suddenly loose a lot of braking power, but not all of it. one front and one rear brake will still work for a short while.
-Mike
[SIGPIC][/SIGPIC]
Catch you next at: ? Auto-X ?
Old 09-25-2006, 06:01 PM
that is what i was thinking going to hapened!
i odered new ss lines from Dayles.
thanks for help guys
Bart
Old 09-26-2006, 01:00 PM
Hose92SVX Hose92SVX is offline
Good eye, you'd think because my last name is Hose I would know all there is to know about hose's but I don't. I'm gonna have to check my vehicles lines more often, I've been taking them for granted.
