Old 08-15-2006, 01:09 PM
Electrophil's Avatar
Electrophil Electrophil is offline
Which manual is "that" in??
To do list when replacing timing belt
I've been searching for a "do all" list here when replacing the timing belt, and can't find one.
Actually I think I have a cam seal leak, and the timing belt is a "While 'they' are in there... thing.
Is there a list anywhere that tells all the things to do while the front end of the engine is open? Like water pump, cam seals, etc., etc. ?
Robert
Is Bush in jail yet? (Looks frantically at watch, then back up) How about now? Now? Come onnnnnn...... Someone freeze me until January, this wait is killing me.
Update: 09 January, and still not in jail! Wassup??
1992 Teal LS-L - 160k (Now new and improved with perfect paint!)
Old 08-15-2006, 01:19 PM
Water pump
Thermostat
both cam seals
crank seal
replace any timing belt idlers that aren't silent when you spin them.
Hope that helps...
Old 08-15-2006, 02:16 PM
dcarrb dcarrb is offline
I'd add that little thermostat bypass hose (or whatever it's properly called) to Huck's list.
dcb
Old 08-15-2006, 03:53 PM
Thanks guys.
I'm going to do a search on the bypass hose. I missed that one.
Robert
Old 08-15-2006, 08:12 PM
cam caps. I think 40% of oil leaks up front are caused by the caps that seal off the intake cams(top ones) There a black caps... nothing special but it makes a big difference
Old 08-15-2006, 10:38 PM
Is this the same as a cam seal?
Robert
Old 08-16-2006, 05:08 AM
Nope, the lower cams have a seal, but the top cams have a cap, as they don't protrude out the front of the head....I've never replaced them on an EG33 but it wouldn't be a bad ideal, I'd think they'd only cost 5-10 each....
