Old 11-29-2004, 04:34 PM
Zaba
Tranny
I have a My tranny up/down shifts at random, especially between 30-60MPH 50-100 km/h....any ideas?
Old 11-29-2004, 11:23 PM
Re: Tranny
??? could pls elaborate more ???
Old 11-30-2004, 12:43 PM
ilsegretosvx
yea, the idea is save some money for a new tranny, the tranny brake band might be slipping. It can be adjusted but its a temp fix.
Im speaking of experience.....I have a SVX with a dead tranny right now.
Old 11-30-2004, 04:57 PM
lee lee is offline
it's possible that the dropping resistor is disconnected or has failed. Can't say I have any idea why, but it seems to cause gear hunting between 3rd & 4th on some transmissions
Old 12-05-2004, 10:35 AM
Zaba
Tranny
It has an updated tranny, done by a dealer about 6 yrs ago...it seems to get worse with the cold weather, it gets a little better when tranny is warm. Where would the dropping resistor be, and how can I test/check it. The car sat for about 9 months, I was told the problem was not there before...
Old 12-05-2004, 12:33 PM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Re: Tranny
It's located on the inner fenderwell by the battery...
-Chike
2006 Steel Gray WRX TR (sold)
Old 12-05-2004, 03:44 PM
Merz's Avatar
Merz Merz is offline
halfsharkalligatorhalfman
i dont mean to jack your thread, but does anyone know of a source for 4.11 4eats? Is there a place online that sells them? I think my tranny is about to go also, i wish it would just hurry up so i can stop worrying about it. Thanks
`92 pearlie 220k
Tranny Cooler, shift kit, stage 1v4, d/s rotors, axxis pads, Perrin Pulley
'00 GMC Sonoma ZR2.
Old 12-05-2004, 03:54 PM
Merz's Avatar
besides a junkyard.
`92 pearlie 220k
'00 GMC Sonoma ZR2.
Old 12-06-2004, 04:08 PM
I would check out your TPS. If it's sending erratic readings it can confuse your tranny into thinking you just floored it even though you didn't move the gas pedal.
Old 12-11-2004, 12:46 PM
Zaba
I checked the dropping resistor, it's connected...but how do I check if it's not defective?...I'm going to my mechanic on Tues. as I don't know how to check or where to look for the items suggested. I'll bring a sugestion List with me... Unless someone can suggest things I can check myself....
Old 12-11-2004, 01:42 PM
SubaSteevo's Avatar
No longer blue member
Do you usually drive in 'D' or '3'?
-Steve
01' MSM Lexus IS300
Old 12-11-2004, 04:35 PM
If it turns out you need another resistor I'll sell you mine so you don't have to worry about duties/taxes coming across the border.
