Old 09-10-2007, 07:28 PM
oneringer oneringer is offline
Unhappy Engine shutting off
'92 shuts off while driving. No hesitation or noise, lights, radio, etc stay on. Wouldn't even know it wasn't running except for losing power steering. After it shuts off, you can start it right back up. Any ideas?
Old 09-10-2007, 07:30 PM
Wikedjuggalo's Avatar
Rebuilding
People will probably say MAF Sorry I can't help never had that problem. Alot of post on Engine's dying try searching
Old 09-10-2007, 08:25 PM
JaySVX's Avatar
JaySVX JaySVX is offline
I would vote MAF first off. But you'd know it, it would sometimes not start back up. If you have a manual trans, that might be it. It occurs occationally where the compression of the engine, when you press in the clutch from high rpm, it'll drop down low, then not recover, and simply stall.
*No SVX at the moment...*
1987 Winnebago Elandan 35'
2001 Yamaha Roadstar 1600
Old 09-10-2007, 08:27 PM
Automatic, and there's no hesitation or anything. I've had the MAF go bad before, and the car ran badly.
Old 09-10-2007, 08:59 PM
Manarius's Avatar
Manarius Manarius is offline
I would suspect MAF as well.
-Jason
-Obi Wan Kenobi
Old 10-02-2012, 02:11 PM
Pierre-Olivier's Avatar
Pierre-Olivier Pierre-Olivier is offline
Re: Engine shutting off
What it is a MAF ???
Old 10-02-2012, 02:21 PM
Mass airflow sensor located on the air intake snorkel
Old 10-02-2012, 02:31 PM
OK merci, c'est le capteur de débit d'air massique en français ?
Old 10-02-2012, 02:57 PM
What he is saying:
Re: Engine off shutting
OK thanks, this is the French mass air flow sensor?
Old 10-02-2012, 03:11 PM
What he is saying:
Do you speak french, Conn SVX ?
