Heat Shields
I was wondering if I can just have my heat shields taken off? Will it mess anything up?
When I was getting a new axle put on the mechanic says he would take them off but I wanted to ask u fellas first cause most mechanics dont know alot about these cars. so yes or no... |
Why did you want to remove them?
They Rattle like hell... and they are quite corroded.
Just be aware that parking on grass with no heat shields = fire.
lol is that it...? I mean as far as my car goes it wont hurt anything else...
Are you sure it's the heat shield(s)? Other things will make terrible noises under an SVX, i.e., resonator, cat, etc. Take it from one who knows.
- Jim
- Jim '02 Outback - Wife's car '96 Legacy Wagon - Son's car '95 Legacy Sedan - #5 Daughter's car '93 Impreza Sedan - #4 Daughter's car '92 Claret LS-L - My car ____________ TOTAL = 595,000 Subi miles |
I think the heat shields also help the converters heat up quicker.
Dave |
well im pretty sure its the shields, I they are loose enough to be moved... and the mechanic was trying to charge me 50 dollars to take them off.. I can do them myself. Arent they just bolted on.
Yes they are but good luck removing them as most have been rusted into place.
When I had my resonator replaced with a straight pipe on my pearlie, the muffler shop just cut the off in sections with a torch in about 2 minutes. No charge.
Just wedge some asbestos, or some other non-flammable material in there, & tighten as much as possible. Mine are still intact at 138K, & been tightened up only twice in over 4 years.
Ron (tight most of the time).
Good s**t happened. 69 was worth the wait. '92 stock semi-pristine ebony - 160K '96 Grand Caravan - 240K '01 Miata SE - 79K '07 Chrysler Pacifica - 60k - future money pit. |
I looked at them and Im afraid if I try to tighten then they will just crap out... Kinda corroded. Anyways I also tried clamps in a few spots didnt do anything..
And see from what I notice is that on my car they only rattle when its cold, so when it heats up Im assuming that they expand and tighten things up a bit. whats asbestos?? |
Thread Tools | |
Display Modes | |
