Old 05-09-2007, 10:03 PM
odepaj's Avatar
odepaj odepaj is offline
Killer of threads
Wont Start
My black '92 wont start, I cant find out why. Its getting fuel and spark, the timing is fine. I pulled a cam/crank sensor awhile back but cleaned them both and then cleared the code and its not throwing the code anymore, I also swapped them with known good sensors. The battery was alittle low, but I swapped a known good battery and still nothing. The starter is good, but I guess just to be sure I'll probably swap a different starter in. It's probably gonna get towed to a shop, because I have no ideas left.
Dustin
-Dustin
Old 05-09-2007, 10:09 PM
kis86's Avatar
kis86 kis86 is offline
replacing something or another
Send a message via MSN to kis86
Yuck
Does it even try to turn over...whine, click, anything?
Old 05-09-2007, 11:37 PM
Trevor's Avatar
Trevor Trevor is offline
You say that you swapped in a "known" good battery. Are you sure on this.
Are the head lights bright? Do any lights go very dim, i.e. nearly out, when you try to crank the car if they are switched on while cranking? If so, the battery is NBG.
Trevor, New Zealand.
Old 05-10-2007, 06:23 AM
odepaj's Avatar
Killer of threads
kis86, it turns over but doesnt start up.
Trevor, The battery in it now was tested at Wal-mart and Autozone, it was low but then sat on a speed charger for 2hrs. It starts out fine, but the lights will dim alittle after trying to start the car for awhile. I also tried the battery from my '92 pearly (that car starts just fine) and I got the same thing, turns over but doesnt start.
Thanks for the quick response.
Dustin
-Dustin
Old 05-10-2007, 07:28 AM
kis86's Avatar
Huh...
Well, it isnt getting proper spark, proper fuel, or the timing is off. If it turns over...it couldn't be the starter. You eliminated the possibility of a bad battery as well.
Ideas:
A blown fuse to the fuel pump
Bad fuel pump
timing belt off
cam sensor
bad plugs?
Found the following on another website:
"The first thing to do is to see if it lost spark or fuel. What I suspect is happening here is the injectors are leaking down into the cylinders thus flooding the engine. The way to test for this is to put a fuel pressure gauge on it, pinch off the feed and return lines and watch the fuel pressure gauge. If it drops then you know you have leaking injectors."
Might want to try holding the gas pedal down when starting...
Car problems suck! I've owned my svx obly a few months and have had enough issues to last a lifetime. but...I still love it
Old 05-13-2007, 12:20 PM
cozykat's Avatar
cozykat cozykat is offline
Still rebuilding my block...
Alcyone Silver Contributor
Send a message via AIM to cozykat Send a message via MSN to cozykat Send a message via Yahoo to cozykat
Originally Posted by odepaj
The battery in it now was tested at Wal-mart and Autozone, it was low but then sat on a speed charger for 2hrs. It starts out fine, but the lights will dim alittle after trying to start the car for awhile. Dustin
Do you know what voltage reading you are getting off your battery? It seems to me, if my battery gets below 12v it stops starting. Different vehicles might have a slightly different voltage acceptance. You could try my battery sometime. It's a brand spanking new red top but if you break, you buy! Just kidding, its got a great replacement warranty. I only suggest the battery again because your issue really does sound like mine from two weeks ago and in my case, it turned out to be the battery. Weird, I know.
~Marisa
Marisa
'93 LSL Anniversary Edition - 02/93 - 150,998 Daily Driver - Forged EG33 (long block), 6MT swap, and re-upholstered interior
'92 Pearl - 100k Side restoration project
Locker | Old Locker | Shutterfly | ReadingIX | Facebook | Instagram
Old 05-13-2007, 03:22 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Check your battery connections and vacuum lines.
Old 05-10-2007, 07:59 AM
dcarrb dcarrb is offline
Can't see much point in that if the engine is turning over as it should.
Assuming it is turning over, I second the aforementioned tip of holding the accelerator pedal to the floor. This worked for me when my teal had a hard-starting spell.
dcb
Old 05-10-2007, 08:19 AM
odepaj's Avatar
Killer of threads
The fuel pump is working, I can hear it cycle on with the key in the "on" position, I also pulled a fuel line after the fuel filter and turned the car to "on" and gas sprays out. I pulled all the timing covers and checked the timing, its dead on. I've also swapped the old cam/crank sensors for the ones out of my pearly (that car still starts perfect with the cam/crank sensors from my black car in it). Plugs could be one thing but I did them 2k miles ago, I cant see all 6 or even 3 plugs going bad all at once (the engine will run with two dead cylinders). I know the coils are fine, I checked them all.
I saw the gas pedal thing in a different thread when I was first diagnosing the problem, I already tried it and it had no effect.
Dustin
-Dustin
Old 05-10-2007, 08:44 AM
cdvs cdvs is offline
How do you know the injectors are working?
Starting fluid?
Old 05-10-2007, 09:05 AM
JaySVX's Avatar
JaySVX JaySVX is offline
If it turns over, it's getting fuel, and it's getting spark, there is no possible way that it would not start, simple as that. One of those three things is not occuring, and you can easily check spark and turning over, which leaves fuel. I would start there.
*No SVX at the moment...*
1987 Winnebago Elandan 35'
2001 Yamaha Roadstar 1600
Old 05-10-2007, 09:28 AM
Unless it is out of gas. Is the fuel filter clogged? Just a thought.
