Old 09-16-2008, 02:08 PM
bwb3's Avatar
bwb3 bwb3 is offline
Cruisin' in Gator Country
Code 34 EGR Selenoid Valve Inoperative
As noted in the title, I'm getting a code 34 and am not sure how to tackle the fix. The car runs a bit rough and is also throwing a code 28, knock sensor. I just replaced the same one on SVX #1 so know how to tackle that. I checked at SubaruParts.com and there are a lot of pieces that make up the ERG system. Is thare just a valve you replace?
Your help will be appreciated.
Gene
Gene and Ben
Old 09-16-2008, 02:59 PM
I'm lost but if I had to replace something my money would be on part 1 or 7.
Nothing else seems to have any moving parts.
Old 09-17-2008, 11:10 AM
bwb3's Avatar
Re: Code 34 EGR Selenoid Valve Inoperative
Part 1 is $101.66, Part 9 $48.63. I was hoping to at least narrow it down.
Gene
Gene and Ben
Old 09-17-2008, 12:39 PM
They're both valves. :/ Maybe try removing them and seeing if either one is stuck or gummed up.
Old 09-17-2008, 02:08 PM
kwren's Avatar
kwren kwren is offline
easier said than done... LOL
Old 09-17-2008, 05:49 PM
True but I figure at least one has to come out eventually. This way you might be unable to ungunk one if it's just gummed up with junk.
Old 09-20-2008, 12:05 PM
bwb3's Avatar
For the next person who has an ERG problem, I found this excellent thread.
http://www.subaru-svx.net/forum/show...valve+location
Turned out I had printed it out a couple years ago but forgot I did. I'm going to give the non-replacement tips a try.
Gene
Gene and Ben
Old 09-20-2008, 03:18 PM
I guess Beav hasn't been around for a while. This pic is quite useful.
/saveas
Old 09-21-2008, 07:53 PM
Ken92SVX Ken92SVX is offline
When I had the 34 code about 2 years ago it was caused by a EGR sensor that is mounted under the intake manifold on the right side of the car (passenger side). I do believe that there are two sensors, but thats the one the fixed my problems.
I hope this helps.
Ken
