Old 03-14-2009, 06:28 PM
Billyboy70 Billyboy70 is offline
Still am losing power.
So today I spend about three hours looking into what could make my svx lose power across the boards. First I thought it may have something to doing with the key switch. Nope that wasn't it at all. Then I Thought it be the the plugs that connect to the firewall from the wheel. Nope that wasn't it either.Then on to The fusable link. That has some corrosion on the end connecters. It om's out fine, Think of replacing it anyway. Anybody have this problem before. Help Please...
Old 03-14-2009, 06:30 PM
Wikedjuggalo's Avatar
Rebuilding
Re: Still am losing power.
Could you explain in detail what is going wrong?
Old 03-14-2009, 06:32 PM
is it drawing power over time?? Or just not giving you anything anytime?
Old 03-14-2009, 09:24 PM
Earthworm's Avatar
Meow!
A bit of history would be helpful in diagnosing this issue.
Old 03-15-2009, 06:02 AM
Thanks for the replies,,
So it start with the engine felling like it was losing a little power from time to time. The it became more frequent. One day it jump to the next level when the light, radio, windows, and etc. There seems to be a connection with the car being bumped around. Like when you were a kid and playing with the light switch turning it off and on. If the engine is over more then 2000 rpm it tends to stablize for the most part. Then was one day I smelled wirers or plastic burning. The trouble is. If it was in the cab of the car I wouldn't been able to tell because it could of very well been in the engine area and got sucked into the venting. This I know because I ran a test with starting fluid. I have searched the car all over. The only area that I found any wires discolored were at the fan circuit board beside the main fuse control panel under the hood.
Old 03-15-2009, 08:57 AM
redlightningsvx's Avatar
Collision Refinishing Tech
Sounds like a bad alternator?
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 03-15-2009, 09:14 AM
kwren's Avatar
kwren kwren is offline
yup............................
Old 03-15-2009, 09:23 AM
Earthworm's Avatar
Meow!
Or simply a loose belt.
Old 03-15-2009, 09:53 AM
bad alt overcharging??
Old 03-15-2009, 10:09 AM
kwren's Avatar
Actually a bad alternator can overcharge and blow up a lot of electrical components at the same time, in a second.
Time will tell!
Keith
Old 03-15-2009, 12:09 PM
Time will tell!
Keith
I know, thats why I said it... I am confused as to the rest of the story
Old 03-15-2009, 09:57 PM
I'm having that trouble. I just don't know what could make the car shut down. I'm going to look into the alt asap. I will be at the car in the am to look into the problem once again. Thanks for the replies again.
Old 03-16-2009, 10:33 AM
Mephis Mephis is offline
On my XT6 I had a hellish nightmare of charging system issues, which sound exactly like your case.
My final solution was to make reinforced fuseble links for it and rebuild the plug for the voltage regulator on the back of the alternator, then make a ground wire from the engine fusebox directly to the battery for redundancy.
That made it bullet proof. Might start inspecting plugs 1st off.
Old 03-29-2009, 07:15 AM
Thanks for your help. I did find a ground wire to be the cause of the short. It is working great now. If I can only think ground next time instead of power.
