#32
no not exactly. The car doesnt shake or shudder. Ill give it some gas and it with stop and the rpms will stay in one position for a sec and then boom im off. Its definitley an O2 sensor or fuel filter or something along those lines. The car has been acting absolutley perfect these last 2 days even with the a/c on. I dunno what it is but ive let it warm up fully for the past 2 days. Maybe thats what it is. Could the ECU know that i did this? Im not complaining....this car is a blasttttt to drive when running right.
#33
Re: Acceleration problems...please help me find a solution
Were you ever able to resolve this issue? My '95 is doing almost exactly the same thing. When I go to pass someone in a totally platonic, non street racing fashion, and press hard on the Go-button, the engine just chokes up, Granny Mode kicks in and I accelerate like a Rascal with low batteries. Same thing around corners when I lay into it. Not every time mind you, usually after sitting in traffic for a few minutes and occasionally it just starts misbehaving without any 'triggers'. It's not consistent enough to pinpoint the exact cause though. If you get a moment, could you list what you have done to fix/attempt to fix the problem? I'll try and start working from the other end of the spectrum, and see if we can't figure this one out with the least amount of capital. I'll reread this thread and look for other ideas.
'95 Subaru SVX L-AWD 88K miles. |
#34
Re: Re: Acceleration problems...please help me find a solution
1. Clean the throttle body 2. Inspect spark plugs 3. Change O2 sensors and fuel filter I am going to clean the throttle body before i do anything because that may in fact be my problem. A member did PM me and tell me he had the same problems with his '93. He told me he replaced the O2 sensors and fuel filter and its working great now. But do clean the throttle body before ya do anything else. I just have no time which is why i havent gotten around to it. But this problem only happens in very hot nasty weather. The car runs pretty great for the most part in cold weather.
#35
Re: Re: Re: Acceleration problems...please help me find a solution
I'll start with throttle body and go from there. Thanks.
#36
Re: Re: Re: Re: Acceleration problems...please help me find a solution
#37
I have the same problem, although I don't think mine is anywhere as severe. She still runs super strong, but I notice hesistation on acceleration - especially when it's cold.
here's my scenario: From a stop, lightly accelerate where the Revs 'll go to about 1,500 then the sputter down to maybe 1250 (but you can feel it) then it launches back to normal (1500+ RPM) ......does all this while remaining constant on the accelerator. If i just hit the pedal moderately it's fine - aggressively it's also fine ....floor it and it's still fine. I just figured this to be the problem that ECUTune's stage 1 chip is to fix. I'm also due for a major 60k service, so after I do all that I'll see if it still does it. Have you tried replacing the basics? Like plugs, clean the air filter, fuel filter, pcv ....all that?
Mike - Proud owner of a Pearl 92 SVX LS-L 5MT with 78k miles and climbing 5-Speed Status: DONE! Lambo Door Status: On hold but will be a success 04 WRX 5MT, STi Short Throw Shifter, Group N tranny mounts, AZA Z-2 18x7.5 Rims, slotted/cross drilled rotors, stainless steel lines, 35/20% window tint, ecu bead crush, power mode button; 7" In-dash touch screen LCD, mobile computer, voice recognition, alpine PXA-H701 DSP, 2 JBL amps, focal speakers all around, 5 farad cap, and fiberglassed subs in the trunk. The Mobile Computer Interface - featuring the SVX | My Locker | My Secret Stash |
#38
Yeah if i floor it then the hesitation never happens. I havent changed any of those but they are definitley on my to do list but only after i get the throttle body cleaned. Can anyone explain why this happens? I havent noticed this in other cars.
#39
Just a little update for everyone here about this issue incase you care . I bought a K&N air filter from Chike back in november and ever since i instaled that the hesitation has not returned. Of course the temps have been freezing but when ive ran the car with the a/c on or defrost on there was no hesitation. The only hesitation i get is the normal hesitation when the engine is cold. I wonder if maybe the new air filter has made the ECU settle down or something . The real test will be in the summer when it gets hot and muggy outside. Does anyone have any ideas why a car would run so sluggishly during the summer as opposed to the winter? I am also going to be cleaning my throttle bodies this week sometime weather permitting and i went to the auto store to get throttle body cleaner but they were all out.....i have fluel injector/ air intake cleaner....can i just use that? I have 2 cans of carb and choke spray in the garage but those were my dads and havent been used in yrs...probably 10 years or so.
#40
Anything more to report ?? Reason I ask is our car does something similar when you are gentle with the pedal; you want to increase gently in speed, or when applying the throttle from a junction, you get sweet F.A. Then along comes the power in a big "lump" making you race off like a scalded cat.
Only the depth varies.............. |
#41
