Old 04-04-2011, 09:11 PM
bricud bricud is offline
Unhappy 1994 Blue Svx FOR SALE/PARTS
I recently slid off the road and wiped out the drivers side of my 94 SVX. Although it is driveabe, I think it would be better to part out. It has 147K miles, but I recently did a bunch of work. At 140K, I replaced the engine with a JDM import. It had about 50K on the engine at the time. Before installing, I replaced the water pump, timing belt, all other belts, replaced all hoses, replaced the cam seals and valve cover gaskets. This is a non EGR Engine if it makes a difference. It runs like a top. You can still start it up and hear it run. Not sure about the history on the tranny, but it may have been rebuilt before I bought the car. It looked really clean and has a blue torque converter?? I also put on a new set of tires. The only mod was to put in a ECUtune 1v5 chip. The interior is near perfect.
Anyone interested in the car as a whole or the engine/tranny or other parts. Hoping it can help someone out.
I plan to see if anyone wants the whole car for a week or so, then I will offer it for parts.
Let me know if interested.
Brian
Old 04-04-2011, 10:09 PM
Re: 1994 Blue Svx FOR SALE/PARTS
Please use the following template to list your car. We need more information than this. Be sure to list the VIN as well. Thanks
Old 04-05-2011, 08:36 AM
Here is the format requested.
Location of the SVX: Brownsville, MN
Year:1994
Model:LSI
VIN:JH1CX3351RH101759
Manufacture date:11/93
Paint Color: Laguna Blue
Interior Color: Black/grey
Miles:147xxx
Options: All options. Sunroof,
AWD or FWD: AWD
Modifications: ECUtune 1v5 chip
Major service: engine replaced 6Kmiles ago with jdm replacement. New timing belt, water pump, accessory belts, plugs, cam seals, valve cover gaskets 6K miles ago. New tires 6K miles ago.
Engine Condition: Very good. No leaks, runs great.
Maintenance Records: None.
Transmission condition: Shifts normally. No known problems.
Glass conditionrivers side windows broken out. Passenger side, windshild adn back glass good.
Type of tire and remaining tread: 6K on new tires. Fuzion HRI 225/50/R16
Type of wheels: Factory stock. Fair.
Interior condition:Very good except passenger visor drooping. Driver door damaged.
Body condition: Poor. Damaged Drivers side (all) Minor dent in hood, passenger fender dented. Passenger door good. Rear deck good. No damage to headlights. Front bumper needs paint.
Known defects or problems: major body damage.
Comments about the car: Sideswiped several trees. Damage to passenger side. Still drives, but is parked.
Asking price: $1000 for entire car or will part out.
Old 04-08-2011, 12:06 PM
Anyone interested in the whole car? Had several inquiries for part. If no interest in entire car in next few days, I will begin to part it out.
I will pull motor and make available for $500 for anyone interested.
Brian
Old 04-09-2011, 10:41 PM
cooljam's Avatar
cooljam cooljam is offline
I'm looking for the drivers side window regulator, not the entire part, I just need the mechanism that connects the window to the metal wire, mine broke so the window won't go up or down. I was also looking for the drivers side visor and the radio door if yours is brown.
pm me if you have these parts and and a price.
thanks,
Josh
Old 04-10-2011, 09:32 AM
XxMattrimxX's Avatar
XxMattrimxX XxMattrimxX is offline
Talking Re: 1994 Blue Svx FOR SALE/PARTS
I am looking for the light bulb socket for the back drivers side break light. light pictured below:
And the part im looking for is here:
Thanks! Mine is merely held by some sticky black crap.
Old 04-11-2011, 08:52 AM
B 4 You's Avatar
B 4 You B 4 You is offline
#lolsvx
how are your hood and trunk struts? :]
1992 Pearl White LS
Owned since 2009
175k Miles
2005 WRX manual swap
Rear wheel drive
K-Staff front bumper
Delta Speed side skirts
JDM clear corners
Smallcar grille
Subaru XT steering wheel
Subaru XT shift knob
First bagged SVX in the world
Old 04-11-2011, 09:04 AM
Freeman's Avatar
Freeman Freeman is offline
Unregistered User
Probably just like everyone elses.. Don't buy used struts unless you plan to rebuild them.
Mods: ECU bead crush, 15 min mod, 20 min mod, drilled/slotted rotors & Axxis ceramic brakes, SS lines, 17" Evoke F1 wheels, XS-HF137 Sony Xplod speakers, 6000k HID's (lows & fogs), resistor mod, 1˝" Sleek Spoiler mod, custom exhaust by svxfiles, '02 WRX aluminum racing radiator by svxfiles, Summit Racing 400# x 300# springs w/ Koni's by svxfiles, ClassGlass fiberglass hood /w scoop, Nevin's rear sway bar, '97 grille, phenolic spacers, custom LED interior lighting, custom paint.
Old 04-12-2011, 09:10 PM
Driver's visor is great. No sagging. will verify door color. wiring parts should be fine. Will take off skin on driver's door to verify part you are looking for is not damaged. That door took a pretty good hit.
Will wait two more days before making any for sure deals for parts. Have someone interested in entire car. If they don't confirm in a couple of days, Will begin parting out.
thanks.
Brian
Old 04-13-2011, 08:40 PM
Thumbs up Re: 1994 Blue Svx FOR SALE/PARTS
Ok great thanks! Send me a PM with a price on that light socket clip if it becomes available!
Old 04-14-2011, 01:02 AM
SVXalter's Avatar
SVXalter SVXalter is offline
What kind of condition are the seats in?
-Dan
1996 Polo Green SVX L - 85k
1992 Ebony SVX LS-L - 193k (parts)
Old 04-16-2011, 12:04 PM
Old Fogey
Available new from dealer at reasonable cost. subaruparts.com
Quantity Part # Description List Unit Price Price
[OUT OF STOCK] 84931PA010 Socket $13.87 $10.57 $21.14
Subtotal: $21.14 per pair
[green] Currently in Stock (usually ships in 1-3 business days)
[yellow] Usually ships in 4-10 business days
[red] May be discontinued
[ Secure Form ]
Glenn
Old 04-25-2011, 01:38 PM
john tolento john tolento is offline
hello,i need a good transmission for my 94 svx.do you have one? how much? thank you,john
Old 04-25-2011, 02:11 PM
Ilovesvx Ilovesvx is offline
are you looking for AWD or FWD?
Old 04-26-2011, 04:32 AM
[QUOTE=Ilovesvx;674797]are you looking for AWD or FWD?[ i have the awd 94
