#31
i guess i was under the influence that your ECU upgrade was tunable? Are you including software to adjust the maps or am i mistaken? With a 100 shot my 175k motor had no problems what so ever. I normally run a 50 shot while cruising around town. When running 100 dry i use 104 as well. Scrapping my kit is not an option I dont have much money at all, im in debt up to my head with college . All i really need is to get rid of the 6500rpm fuel cut, its incredibly dangerous to bounce off fule cut with nitrous, so i end up shifting way early, the twin knock sensors do a good job of pulling timing it seems,as zero audible knock is heard witbn 100-120 dry phil
~Phil Teal 1992 Subaru SVX Turbo - Sold in May 2011 to peace-frog. Last edited by Phast SVX; 02-21-2004 at 09:37 PM. |
#32
~Phil Teal 1992 Subaru SVX Turbo - Sold in May 2011 to peace-frog. |
#34
#35
phil
#36
Wha, What are you talking about? That has nothing to do with why I want Nitrous. No really, I don't know where you would get that idea from?
92 SVX #772 140k 6speed, ECU Tune stage II, Koni/Ground control, 3,270lbs. 91 Legacy Turbo 5spd. FMIC, crappy stock turbo, ACT clutch. 78 BRAT (New toy) (Soon to be EJ22T powered) 90 240 SX. RB25 powered!! DRIFT!!!111!!! (GF's car) To many cars to spend time on teh web! |
#37
I like the sounds of that. About how much HP are you expecting with the off nitrous codes? How much development time do you need?
#38
#40
Cool.
#42
Nevermind.
#43
7400 rpm
Chuck D. 1992 Subaru SVX LS-L - Heavily modded turbo 2002 Subaru Impreza WRX- Turboxs stg3 & Susp. Mods |
#44
Re: 7400 rpm
I changed the rpm limit for the sake of those running 5 speeds who want it raised and one person in particular talking about changing his cam timing. |
#45
Chuck,
My appologies for being grumpy. It's just frustrating after spending so much time pouring over code to try and keep up with informing everyone on progress and finding out what everyone wants to handle questions that were covered by previous posts. |
