Help removing window motor
Does anyone have some advice or a quick how-to for removing one of the power window motors from the doors? Specifically the passengar side one, but they are probably similar.
I'm sure it is pretty straightforward, but I need to get it today from a parts car and we are having a week of torrential downpours and high winds so I want to spend as little time as possible out there in the lot figuring it out. Kinda a quick swoop in, do the deed, and then just as quickly swoop back out mission. Thanks!
Troy 1992 SVX LSL "Serenity" 250,000 miles! I don't care, I'm still free, You can't take the sky from me... |
Its easy as long as you have a jumper box or battery nearby. when you remove the panel
1- unplug the green conection 2- take battery with some wires and touch to the prongs on the motor side till window goes down about half way ( till you see the 2 bolts holding the window to arms) 10mm bolts. Pull the window back up by hand to get it out of way. either tape it up or set it down in the door after you are done so it wont break. 3- there should be 4 bolts holding motor( 10mm ) remove them then i think 2 more bolts holding a track part and you are free |
