Passive 4ws
Can anyone explain the SVX's passive 4ws system?
Habesha,
Yes. Sorry, but on USA model SVX's there is no 4WS system, passive or otherwise. Larry III |
Oooo this otta be good
Randy..... Eddy. Let's go!!!!
Seriously, you can perform a search on this subject, it goes by many names, passive AWS, NOT AWS, 4WS, etc. A large disagreement over this subject is available. My opinion.....well it's NOT steering in the traditional sense, specifically, there is no tie rod to 'steer' each wheel, but the rear wheels DO in fact toe in and out slightly with differing loads. Any arguments with that will be delt with swiftly. Is that steering? In some minds, yes and others no. You can look at the suspension in detail an make your own opinion. I'll have to go get that nice diagram of the rear end and post it someday. Nowhere in my official Subaru literature does it mention 4WS or AWS, so where did you hear such terms?
Jeff '97 LSi, Ebony Pearl, LSi, 155K |
Dang!
Nice link!
I can sleep at night now.
I will just sit, watch and whistle. I want to see if anything repeats from previous posts...
Lwin
Some Car Rewview
I came across the term on some car review or another of the SVX... beats me, lol
it may not actually steer in the traditional sense but it does......
seem to aid or assist in steering. that was a pretty good description, that was my first time reading that. it didnt really appear to be an ad more like a honest description of what is occuring based on their observations or design. just my opinion.
1994 SVX, true dual Magnaflow exhaust, K&N filter, 17" Enkei RS6 wheels, Bridgestone Potenza RE730 225/45/17 rubber, zinc plated cross-drilled rotors with yellow painted brake calipers. B&M tranny cooler rated at 19,000 GVW. GC springs and Koni strut inserts installed and the car is lowered two inches all the way around!! "Too much fun to drive!" |
Re: Oooo this otta be good
Pull my finger! |
is there anyway to disable it every car that came with 4WS handles better without
It IS steering... if you think you can steer your front wheels by removing the rack and using a lever to chage the toe in/out.
If you take steering to mean "cause change in direction" then the answer might be yes. No, I take that back. It is not steering at all-- the toe chage does not occur until AFTER the car has started to turn. The change in suspension geometery is a result of steering, the change in toe does not cause steering. |
