Opening the Headlight
I had my German headlamps come in and noticed it could use a cleaning on the inside. I thought it was some pitting but it seems to all be on the inside. There are some clips that are around the perimeter but are these just popped into the oven to open like others?
I want to make sure before doing anything with these babies.
Re: Opening the Headlight
They all come apart the same way.
What you are seeing on the INSIDE of the lens is not pitting, it is disintegrated glass dust that is from the edge of the projector lenses. The projector lenses lenses are assembled in the housings without a gasket or some sort of cushion. Over time, vibration causes the projectors to move in the housings and chipping off minute shards of glass. Some members have opened up the housings, removed the projectors and cleaned all inner surfaces.. Before reinstalling the projectors, a thin bead of clear RTV sealant was put around the perimeter of the housing as a cushioned bed to protect the edges of the lens. However, it this were me, I would send these rare babies to Prolightz. See more from crazy_pilot's thread here. http://www.subaru-svx.net/forum/show...ight=prolightz crazy_pilot spent about $450.00. His included 12-15 hrs of sanding, polishing, etc. of the plastic lenses, plus the CCFL halo eyes and new projector lenses and new outer film. Your should be a lot cheaper, since all that you may need is a good cleaning of the glass lens and projector lens replacement.
Thats a good idea...
But I will have a hard time holding back from any upgrades while they are up there. Let me contact them and get some prices. Thanks
I'm sure cozykat will be following this closely. Marisa also has a set of glass headlights and she can be as fastidious (can't use the "A" word when talking about a lady) as either of us... probably more.
