Old 12-22-2013, 12:37 PM
shotgunslade's Avatar
shotgunslade shotgunslade is offline
1994 SVXi for Sale
Time has come to sell my SVX. We've been through a lot together, but need room in the garage for an old man car (911 Turbo convertible).
Location of the SVX: Princeton, NJ
Year: 1994
Model: LSi
VIN: JF1CX3551RH102703
Manufacture date: 02/94
Paint Color: Emerald Pearl
Interior Color: Tan
Miles: 105,xxx
Options:
AWD or FWD: AWD
Modifications: Over $40,000 spent on upgrades. Recent complete exterior body renovation and re-painting in original color by Dave Heinrichs. No collision or significant body damage, only door dings, and minor hail damage repaired. Significant modifications and upgrades, mostly by Young Tom, including change to 5-speed manual transmission, upgraded suspension and professionally built engine. Car was dyno tuned showing 246 WHP @5,800rpm, 228 lb-ft torque at 4,500 rpm. Car currently is registered as Collector Car in New Jersey. Below are the modifications that have been made:
•PWR aluminum radiator, silicone hoses
•Inline thermostat; enhanced coolant routing
•External power steering and oil coolers
•Outlaw Engineering forged underdrive pulley
•HKS Cold air intake
•Phenolic intake manifold spacers
•custom grind Web intake and exhaust cams (11 mm lift, 250° duration)
•solid lifters
•CP custom aluminum forged 11 to 1 pistons,
•Brian Crower coated SS intake & exhaust valves
•Brian Crower upgraded springs w/ titanium retainers
•NGK sparkplugs
•New ignition harness
•RallyBob (Bob Legere) ported and polished cylinder heads
•Eagle H-beam rods;
•ACL Bearings;
•balanced crankshaft;
•ARP head studs & fasteners;
•Hydra Nemesis Stand-alone EMS;
•Wideband O2 sensor
•740cc Injectors;
•Walbro 255lph fuel pump
•Upgraded WRX starter
•Equal length SS headers (3 into 1);
•dual Magnaflow cat converters
•2 into 1 into 2 SS exhaust with Bullet muffler;
•2004 WRX 5 speed transmission
•ACT Clutch Kit, Heavy Duty Pressure Plate, Lightweight flywheel, performance disc
•Group N motor mounts
•FrozenRotors slotted rotors fr&r,
•Cadmium plated calipers
•SS brake lines,
•Axxis Ultimate pads;
•Rota Boost 17x8 wheels;
•245/40-17 Bridgestone RE01-R's;
•Koni inserts with Ground Control coilovers, Eibach springs;
•K-Mac camber/caster adjustable strut mounts
•Urethane swaybar bushings;
•Bontrager rear sway bar;
•Urethane differential bushing
•Custom Whiteline adjustable rear lateral links
•Fiberglass hood by Old Tom
•Oil pressure gauge
•Programmable shift light
•Momo shift knob
•Aluminum pedal covers
•3M paint protection film on front bumpers, fenders, mirrors and wing.
Major service: less than 2000 miles ago
Engine Condition: Recently rebuilt
Maintenance Records: partial
Transmission condition: very good 5mt
Glass condition: nick, not spreading in windshield
Type of tire and remaining tread: 245/40-17 Bridgestone RE01-R's;
Type of wheels: Rota Boost
Interior condition: good
Body condition: excellent
Known defects or problems: may not pass NJ emissions. currently Collector Car registratoin, last known emisoins test, passed 2500rpm by good margin; failed idle, maybe because car was just started and cold when idle test was made.
Comments about the car: Great car. Someone needs to buy it and take it back to the track.
Asking price: $16,000 firm
Old 12-30-2013, 06:20 AM
Re: 1994 SVXi for Sale
bumpity bump
Old 12-30-2013, 08:11 AM
gwynethh's Avatar
gwynethh gwynethh is offline
Very fine looking car and impressive list of improvements. Hope it sells for what you want.
Old 12-30-2013, 08:57 AM
Huskymaniac's Avatar
Uses the ignore feature
Ditto. Good luck with the sale. Seems like a nice car. How driveable is it? Does it idle smoothly or is it similar to other cars with aggressive cams?
Tony
Old 12-30-2013, 01:51 PM
It doesn't have the smoothest idle in the world when cold. A little reluctant to start, but once it gets warmed up, it's fine. Have to credit YT with some great work on the laptop adjusting fuel air maps for the Hydra. I dont know if you remember this video of the exhaust note:
http://s203.photobucket.com/user/sho...N0120.mp4.html
Lots of spares. Stock wheels with all-weather tires. Shop manuals.
Old 01-07-2014, 11:33 AM
mikecg's Avatar
mikecg mikecg is offline
Send a message via AIM to mikecg Send a message via Yahoo to mikecg
It's a beautiful car. I hope you have better luck then I did selling mine.
Old 04-26-2014, 03:28 PM
Asking price is down to $10,000. Anyone interested? Got some really good press recently, but it hasn't prompted anyone to make me an offer.
http://bringatrailer.com/2014/04/21/...ubaru-svx-lsi/
Also showed up in AfterDrive. Discussion of Subaru SVX starts at 19:00 in. Discussion of my car starts at 20:00 in.
https://www.youtube.com/watch?v=GdIANn6oO3c
Old 04-30-2014, 04:56 PM
Sold to Rich Chen in San Francisco. Used to be on this network as Supercarnitas
Old 04-30-2014, 05:31 PM
Congratulations. Must be bittersweet.
Old 05-09-2014, 09:57 PM
sicksubie's Avatar
Welcome to the Pcar club
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1995 Guards Red Carrera
1957 CJ-5
Old 04-13-2015, 03:32 PM
SuperCarnitas SuperCarnitas is offline
Former SVX Owner
A belated check-in to this thread. The car is doing well in SF Bay Area, has not seen a track day yet (a Mitsubishi Evo 9 does track duties at the moment, being replaced by Porsche 996TT) but the SVX has been delighting many area enthusiasts on weekend drives.
https://instagram.com/p/ujEFuRnWxV
First time back in SVX in 10 years!
Old 04-13-2015, 04:52 PM
Congratulations. That's a one of a kind SVX.
