Old 04-27-2005, 04:45 PM
Earthworm's Avatar
Meow!
Why you should change your knock sensors
I attached 2 pics (one for each sensor)
After replacing the sensors and cleaning the throttlebody with Mercury Powertune my car idles smoother, a little higher (800rpm) and doesn't try to stall when I push in the clutch while decelerating.
One of the sensors was modified for dramatic effect
Old 04-27-2005, 05:03 PM
Bwana's Avatar
Bwana Bwana is offline
*Special* Member
Send a message via AIM to Bwana
Explain what's wrong with them for us non-mechanical people.
[/COLOR][/COLOR]-Scott My Locker
2014 Grey Ford Fusion 2.0 EcoBoost Bought: 12-5-14
2005 Silver Legacy GT Ltd 5mt. Bought: 3-3-07 Sold: 12-5-14
1996 Brilliant Red L (AWD). Bought: 6-14-04 - Sold: 3-3-07 - 15.370 @ 89.65
1992 Claret/black LS #4086 (GF's). Bought: 6-30-04 - Sold: 7-29-07
1994 Pearl White LSi Bought: 2001? Sold: 2004?
Old 04-27-2005, 05:12 PM
mbtoloczko's Avatar
sans SVX
Sounds like this should be one of my summer projects. :-)
Mychailo
Visit my locker
Old 04-27-2005, 05:37 PM
Earthworm's Avatar
Meow!
Well the housings are both cracked and I figure they were reporting false knock symptoms and unnecessarily retarding the timing.
Changing is not exactly easy without removing the intake but it is possible and it really helps to have 2 people especially when changing the driver's side sensor.
Without removing the intake expect to take about an hour to change both sensors. This includes removing/replacing the alternator.
Old 04-27-2005, 07:29 PM
Knock, Knock
Old 04-27-2005, 07:46 PM
michael's Avatar
michael michael is offline
What Potholes ???
Who's there?
Wanted: Steering Wheel
