Old 03-11-2008, 05:27 PM
JLHollowX13's Avatar
JLHollowX13 JLHollowX13 is offline
Send a message via AIM to JLHollowX13
just thinking....
so my front differential is messed up in the speed sensor gear area, and i thought i remember reading somewhere that the rear has a speed sensor too is that right? if so, is there any way to use the data from that sensor to make my speedo work? maybe wire something up? if so, how would i go about it?
also, how can i go about wiring up the transmission to a switch that makes the awd go to 50/50? i know about the potential binding problems but i thought it might be a good idea to have if i ever needed it in case i got stuck or something and my transmission wasnt doing its job. thanks for any help!
Old 03-12-2008, 03:11 AM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
Your car has two speed sensors because it needs two speed sensors for the transmission to work correctly. The best thing you could do is fix the problem rather than trying to find a way to make the car work properly with just one.
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
