Old 04-15-2007, 07:54 PM
Yes... otherwise it would have been lifted But I am also glad that I can go to the store and buy a 6 rib belt now thnx TOM!!!!
Old 04-15-2007, 08:13 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Now, if "Old Tom" can just get a new drive pulley for his s/c!!
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 04-15-2007, 09:14 PM
-Bill
I just got the pulley installed.
I wanted this one to be a virtual press fit, so.....
I had to heat the new pulley in 212°f+ and have Di try to amputate my fingers installing it.
I now have boost again, but have to have a pass to see the #s.
YT, congrats on your new SpringTime!!!!!
I loved the way those coilovers felt!
OT
Old 04-16-2007, 09:28 AM
OT... just remember, "ground control" while we are racing... I know you already heard this but I know how old people lose their hearing over time
Old 04-16-2007, 10:02 AM
What?
Lose their mind over time?
What?
Old 04-16-2007, 10:03 AM
Ground control to Major Tom....
Old 04-16-2007, 12:03 PM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
I want to be Koni-sized next!
Need money though
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 04-18-2007, 07:05 AM
shotgunslade's Avatar
Tom:
What spring rates did you use?
Old 04-18-2007, 07:18 AM
350 up front and 315 in the rear... although I am still not sure, the fronts may be 450's but i thought it was a misprint
Old 04-18-2007, 07:39 AM
You ready to go for a track day?
Old 04-18-2007, 07:54 AM
hell yeah!!! as soon as I can afford it and I am out of school/work. esp since I am picking up a set of DOT slicks from Ben&Dave
Old 04-18-2007, 08:28 AM
Here is a good one. It is on the long course at Pocono. You should be able to get up well over 130 on the straight. My little NA ride gets up to over 120. It's $250, which is peanuts compared with what you have been dropping into the beast lately.
http://triregionracing.org/Forms/2007PDXad.pdf
By the way, wouldn't take R compounds to a track day until you have a number of them under your belt. They might be just the thing for AutoX, but street tires are better for beginning long-trackers. They have much more progressive break-away, and you can more easily learn how to modulate your drift with your left foot. There have been a lot of posts on this topic recently on the NASA forums. Instructors really don't want to ride with HPDE 1 and 2 drivers with R compounds. These tires hold really high lateral forces, then let go abruptly, sending the noobie driver into the weeds at high rates of speed, along with screaming instructor. Besides, you will learn a lot more and actually have more fun without them. I figure when I get my diploma to go from HPDE 2 to HPDE 3, I'll spring for R's. Until then, Yoko Advan Neova AD07's or Falken Azeni's are as far as I want to go.
Let me know. I'm going to both days for this one. If you want to do both days ($450), let me know, you can have the other bed.
Old 04-18-2007, 10:10 AM
Tim's Avatar
Tim Tim is offline
Is the limitation for the Koni's 400lb/inch?
I'm interested into hear if there's a difference between this set and your old one as far as ride quality and feel.
Tim
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 04-18-2007, 08:44 PM
Tim, as far as I know so far (driven about 7 miles) is that they feel the same... which is really frickin awsome!!!
tom
Old 04-18-2007, 08:47 PM
Im in.... sounds like a blast but I gotta make sure it doesn't conflict with my brother's wedding
tom
