Old 06-16-2004, 11:49 AM
TCamusJr TCamusJr is offline
Uh-Oh Advice needed ASAP
While cleaning my throttle body, the plastic straw-type tip for the Valvoline spray cleaner blasted off and I think eded up inside the butterflies. Should I be worried?
Old 06-16-2004, 12:00 PM
SVXer95 SVXer95 is offline
Word to Yo Motha
I would do my damnedest to get that thing out. I would probably pull the intake if necessary. Definitely pull the TB. You don't want that thing melting in there.
Collin
1995 L AWD
Locker
1987 Porsche 944 turbo
Old 06-16-2004, 12:23 PM
Mr. Pockets's Avatar
Moderator
I doubt it would melt, but I agree - you don't want it in there anyway. Get it out at all costs.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
I know I would not want it in there! Good luck.
Old 06-16-2004, 12:58 PM
I guess I'll wait for a fifth or sixth opinion
If it really is in there (it blasted off and i didnt see where it went, and now i'm not seeing it on the ground or in the engine area) then there's no way I can get it out, since I'm basically working from my apartment's lot with two screw drivers and a vice grip plyer (unbelievable useful, by the way!). I imagine I would need metric wrenches and ratchets and all that good stuff to get at this thing.
Right now I'm lucky if I can reattach all my hoses to my air intake. I've got two more places to plug them back in on the left here, but appear to be two hoses short...maybe they ended up with that straw tip somewhere...
Old 06-16-2004, 01:18 PM
svx_commuter's Avatar
I think it will get ingested and chewed up by th eintake valves and expelled by the exhaust valves. It will prevent the valves from closing all the way until it blows thru.
I wear rubber gloves and spray the cleaner on a paper towel that is folded to clean the TB. I found it to be a rough start if too much cleaner goes into the engine.
SuperbVehicleXtraordinary
Proud sponsor of a 1992 SVX.
Old 06-16-2004, 01:41 PM
Jack
I just cleaned mine last weekend. I sprayed a lot in there and had no problem restarting. I did take the plastic tube off the can becasue they knock off so easy and just sprayed from the can.
Old 06-16-2004, 01:44 PM
Seraph's Avatar
Seraph Seraph is offline
I abuse them one at a time
Take the TB off. There are 8 Bolts if I recall. BUT DO NOT TOUCH ANYTHING. If you do, you WILL need a whole new TB. The adjustments are very small for the openings and are very hard to redo.
Lwin M. Maung (Member # 147)
Current SVX: • NONE
Other current cars:•2001 Jeep Grand Cherokee Black
Old 06-16-2004, 01:45 PM
Yeah, you're not kidding. It was rough start and rough idle like whoa. Kept jumping from like 1500 back to 500 and then stalled on me. I was pretty worried, but I just took her out for a 5 mile spin and now all seems to be well.
Ahhh yours was the opinion I was waiting for! I just needed someone to tell me I have nothing to worry about.
Old 06-16-2004, 02:03 PM
IggDawg's Avatar
IggDawg IggDawg is offline
0h n0es!
Send a message via ICQ to IggDawg Send a message via AIM to IggDawg
I would *strongly suggest* picking up a set of sockets and a driver. even if it';s a 5-dollar autozone set of cheapies. I can't imagine going through life (Automotive life at least) without a set of tools. sockets (and vice grips ) being an absolute minimum.
another cheap but useful tool is a ball joint puller (aka "pickle fork"). I've never used one to pull a balljoint, but I've used it for countless other applications.
if you own a SVX, you should definitely own tools. eat ramen for a week and lay off the Starbucks, and you can afford a decent set.
IggDawg is cool
-IggDawg
1992 Teal SVX LS-L 160k miles
4.11:1 final drive, K&B dropsprings, ART front rotors, stainless steel brake, aluminum underdrive crank pulley, Kuhmo Ecsta Supra 712's, K&N drop-in filter. Previously owned by Alacrity024. FOR SALE
1994 SVX LSi, Barcelona Red #1659, build date 11/93, 117k miles, RIP
ECUtune stage 1, bead crush, smallcar shift kit, TB bypass, SS brake lines, silencer removed, alternator and grounding wires, Mobil1 @ 117k
