Security System - False Alarms Information
Author: Subaru NUMBER: 15-97-93 DATE: 01-26-93 APPLICABILITY SVX SUBJECT: SECURITY SYSTEM It has been determined that the Security System main switch (on the dashboard) of an SVX can be responsible for causing false alarms when the switch is in the off (latched in position). The internal contacts have been found to acquire a film of oxidation and grease which may interrupt the electrical continuity of the switch. The SVX Security System and the main switch are in the process of being redesigned, both to correct the main switch condition and to make the operation of the Security System Module more "user friendly". We expect to announce the availability of the modified system in the Spring of 1993. Prior to the release of this modified system there are some measures that can be taken to reduce the likelihood of switch induced false alarms. Prior to delivery of an SVX to a new owner, perform the following as part of the PDI and/or delivery procedure:
NOTE: DO NOT disconnect the Security System fuse. The tail lights are on this fuse. If you need further clarification on this concern, please contact the Subaru Technical Helpline or your District Technical Manager. . |
