Painted alternator
Well I was changing the hoses and check valve the other day and had my alternator out so I decided to clean it up a bit. I used a small wire brush on my dremel on low speed and removed all the crud off the entire thing. Then used some ceramic semi-gloss black engine paint and gave it 3-4 coats. Here's the final result.....don't mind the dirt on everything else.
Re: Painted alternator
Looks good... Just a question though. Isn't painting the copper coil inside the Alternator bad? Kinda looks like you did that here, but it looks real nice.
"When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car." 92' Subaru SVX LS-L Claret http://www.cardomain.com/ride/3214312 for the pics and stuff
It shouldn't have an effect on it because electricity is still flowing through the wires. I think Mike had his powdercoated and it has no effect. Thanks for the compliment.
Pretty sure Mike had his case taken apart and then powdercoated so therefore the copper inside is still clean with nothing on it. Not saying that painting on the copper WILL be a problem, but it could.
I know but I think he had the wire coated gold because it isn't coppor colored.
Current flows around the outside surface of a wire, not through it. All windings (even those that appear to be bare copper) have been sealed with a high temperature insulating paint before assembly)
That is why you can get water on the windings and not have them short out. I had the windings in my high-output alternator clear-coated to appear close to stock, but many colors are used. Yours were already coated so this is just an extra (cosmetic) layer. .
I taped off the inner copper and spray painted the outer part gold.
It looks good Seth. Now you just need to do everything else.
1991 SVX L JDM |
