Tough Nut To Crack
I was working on changing the front axles in my 98 Legacy and would you know it the nut wouldn't come off. I had a ½” breaker bar and a 3 foot pipe that has been used successfully on several axle nuts in the past but on this one the breaker bar started to break. The ½ impact I have would not budge it either.
So I was thinking, what the heck am I going to do? So I looked at the new nut and saw where the threads were and figured I would try to drill it and expand it. I used these new (to me) cobalt drills that are made for drilling stainless steel. I saw them at Harbor Freight and figured it was worth a try. The drills worked real nice drilling the nut with reasonable effort. Much better than the old bits I usually struggled with. After that I banged on it with a chisel and a punch to expand it off the axle. There is a picture in my locker if you want to see it. The axle nut for a Legacy is the same as the SVX.
Hopefully you didn't damage anything your weren't planning on replacing.
Oh yeah right I was puuting in axles. So the axle thread didn't matter.
If you're returning the axles as cores then some places may not accept them if the threads are damaged.
good work man! - sometimes you have to just step back and find another way to skin the cat.
Dave, I was able to drive the nut around with a punch and hammer. The threads look good.
Re: Tough Nut To Crack
Good job.
