Strange engine problem, need help
Ocassionaly, right after I start to run my car it behaves strangely.
So i'll turn it on and drive it for like 10 seconds when it suddely starts to shutter and jolt. Then it dies. After that it takes a few tries to restart and then if I shift it into Drive or Reverse it dies instantly. So I have to turn it on and let it idle for a few minutes before I can drive it without it stalling. Then it runs a little crappy but after a little time it runs fine. It only does this ocassionaly and it's only started doing it since I installed ECUTune Stage 1. Any ideas? THanks! --Mike
Early deceased SVXWN Member July 1986 -- February 2007 Michael - Duct Tape Man 1992 Burgundy SVX LS-L, 138K: Brembo Slotted/Drilled Rotors, B&M Tranny Cooler and Filter, SmallCar Shift Kit 1992 Burgundy SVX LS-L, 123K: DEAD FROM FATAL HAIL DAMAGE, Parting out so PM me if you need something. "It's only after we've lost everything that we're free to do anything" - Fight Club "This is not my life, this is not my home, this is not me. I HATE THIS!" - Static X |
Smells like Coolant Temp sensor to me.
Yes that's the most likely problem. This problem really starts popping up as temperatures start to get down to freezing.
temperatures aren't approaching freezing yet but it's definitely started to get colder. I ordered the sensor from AUtoZone yesterday as it was only $20. I did a little research and I may also try resetting my ECU. IT may be upset after the new ECUTune.
-MIke
one think you can check too is make sure your air filter is still attached mine use to stall when my air filter disconected
I replaced the sensor and it still has the problem. It starts up cold and acts fine but as soon as I put it in gear (R, D) it dies. I have to idle for a while before it'll run ok.
It's not the air filter.
