Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania
Old 03-28-2005, 09:28 PM
Budfreak's Avatar
Budfreak Budfreak is offline
Banned
Send a message via AIM to Budfreak
Question throttle body bypass
i just got rid of my 87 trans am gta and i had the throttle body water flow bypassed and it worked great. i've never read anything about it on here and was wondering if any knew if it could be done to an svx. it added a good kick to the trans am and i figure it could help the svx too.
Old 03-28-2005, 09:32 PM
Electrophil's Avatar
Electrophil Electrophil is offline
Which manual is "that" in??
Never heard of that... What is it, a throttle body cooler?
Robert
Is Bush in jail yet? (Looks frantically at watch, then back up) How about now? Now? Come onnnnnn...... Someone freeze me until January, this wait is killing me.
Update: 09 January, and still not in jail! Wassup??
1992 Teal LS-L - 160k (Now new and improved with perfect paint!)
Old 03-28-2005, 09:38 PM
michael's Avatar
michael michael is offline
What Potholes ???
It's been discussed and it depends on where you live. You need it to keep the throttle plates from freezing. If you don't get a lot of cold weather or install a valve it's perfect.
Wanted: Steering Wheel
Old 03-28-2005, 10:09 PM
Oh... So this is definitely not a southwest kind of thing.
Robert
Old 03-29-2005, 11:04 AM
svx_commuter's Avatar
It's on here somewhere and has been discussed.
SuperbVehicleXtraordinary
Proud sponsor of a 1992 SVX.
Old 03-29-2005, 11:53 PM
IggDawg's Avatar
IggDawg IggDawg is offline
0h n0es!
Send a message via ICQ to IggDawg Send a message via AIM to IggDawg
I did a step-by-step a while back. got real detailed. I think there were pics in the thread too. It's very simple to do compared to some cars I've had to deal with.
IggDawg is cool
-IggDawg
1992 Teal SVX LS-L 160k miles
4.11:1 final drive, K&B dropsprings, ART front rotors, stainless steel brake, aluminum underdrive crank pulley, Kuhmo Ecsta Supra 712's, K&N drop-in filter. Previously owned by Alacrity024. FOR SALE
1994 SVX LSi, Barcelona Red #1659, build date 11/93, 117k miles, RIP
ECUtune stage 1, bead crush, smallcar shift kit, TB bypass, SS brake lines, silencer removed, alternator and grounding wires, Mobil1 @ 117k
Old 04-06-2005, 08:19 AM
Budfreak's Avatar
Banned
Talking
ok i did the throttle body bypass and it worked much better than i thought it would! it's the best 3 dollars i ever spent! it took 5 minutes and fixed so many things. i used to have a problem with it wanting to stall when i put it in gear regardless of engine temp and now it doesn't do it. it idles a little lower and smoother too. the power feels much better too and it has huge throttle response.i recommend this to everyone of you out there (for as long as it's over 30 degrees out anyway). it's worth every cent and second.
Old 04-06-2005, 08:51 AM
mbtoloczko's Avatar
sans SVX
Even in above-freezing weather, the throttle body water is sometimes needed. The air flowing into the throttle body can cause the butterflies to freeze even when the outside air temp is above freezing (from past experience with another car). I'd wait to use the by-pass mode until the outside temperature is at least 10 deg above freezing.
Mychailo
Visit my locker
Old 04-06-2005, 10:58 AM
PhatWeasel's Avatar
PhatWeasel PhatWeasel is offline
Destroyer of worlds.
Coolant flow direction
Which direction does coolant flow through the throttle body?
'95 Subaru SVX L-AWD 88K miles.
Old 04-07-2005, 02:02 AM
IggDawg's Avatar
0h n0es!
I believe it flows from starboard to port. this is an assumption based on age-old knowledge of EJ25s though. why do you need to know? a bypass should flow in either direction. you deff don;t want to simply pinch off the line. 2 reasons for this. one being that crap will build up at the pinch and will cause a host of problems (whether or not you ever release the pinch) and second, the water also flows through the IAC if I remember right. pinching the water line will cause improper idle since that device relies on the coolant to determine engine temp (and thusly idle speed)
IggDawg is cool
-IggDawg
Old 04-07-2005, 09:32 AM
PhatWeasel's Avatar
I was thinking of installing a diverter valve so I wouldn't need to remove the air pipe to restore the system to normal during winter months. Using a diverter valve on one side and a tee on the other would allow for coolant flow to be switched between TB and bypass. I imagine one would want to diverter valve on the input side and the tee on the output side to keep coolant flow into the TB as low as possible. This method would not isolate the TB, but without coolant flow I imagine it would stay cooler. This also cures the problem of stagnant coolant sealed in the TB all summer. Just a thought.
