MAF Issues continue
Car keeps randomly poppin #23, I've cleaned the 2 OEM MAF's that I have for EG33's, I've read that EJ25D's work as well? I'll keep this short, I've dio'd everything the service manual says to do and everything checks out within spec.
Is there something that could break off inside the MAF housing? I really wanna get this fixed, so I can rule out the other issues the car is having (my random odd transmission shift issue but thats for another day) And the factory SVX MAF has 5 pins but only 4 wires? Or did someone swap one out on me before I got the car?
92 Svx 4.44 swap 198k miles. Toyo Garit KX tires.. my Icetrack car 86 Lifted GL wagon well over 600k miles on the chassis 98 Outback 5 speed 6 inch lift, forester struts/springs 29" tires |
Re: MAF Issues continue
Four wires is right.
Check out the pdf here: http://www.subaru-svx.net/forum/show...ght=MAF+solder Tapani |
Hiya,
Early JDM Impreza's suffer the same sort issue, it is usually in the wire it tends to go brittle and crack and if 2 or more wires do the same on a bend or kink it shorts intermittantly. It is usually not that visable and some of the cable wrapping needs to be stripped away and then re wrapped after a repair with a good insulation type tape. If you have 2 good known MAF's and are getting the same problem I would now be looking at wiring first off. Just another side thought if you have one, JDM Legacy and Impreza's with after market cone type filters throw codes and MAF's go bad through vibration as they are never as solid as a stock airbox. Darren
11/94 SVX Alcyone, Mica Black, VL Spec 4WS, 71K Miles, 1 owner from new & was part of a private car collection in Japan. Nissan R34 Skyline Stagea 91 Lotus Elan SE Turbo 1966 MGB Roadster, Tarten Red, Wire Wheels, Leather, 23K miles from new You can tell the men from the boys from the speed of their toys. |
ty for posting the PDF. Makes it so much easier to understand when I can see pictures rather than just read text, or a horrible FSM image copied to dvd lol.
Keith |
its the symptoms that made me want to tear into it and fix it. Car randomly dies @ stops, bad mileage. Just got done resoldering everything and installed it on the car. 40 mile test drive coming here soon.
Resoldering mine worked great, hopefully it will work for you.
Hope it worked out for you! Keith |
