Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Turbo Projects
Old 06-04-2008, 02:09 PM
Turbo kit, who would be SERIOUSLY interested??
I have full intentions of building a turbo system for my Silver... I have been toying with the idea of offering a full kit w/ standalone engine management as well... There would be two versions.
1st would be a mild kit for a stock engine... Basic maps that allow the car to be driven but the car would need its own individual tune. More than likely using a Gt35r with a large front mount. Possible cost would be as low as $7k.
2nd would be a more aggressive kit for a built engine. Once again basic maps to keep you from blowing it up, but still needs to be tuned. Using a Gt4088R and a larger front mount intercooler. Possible cost would be as low as $8500.
Hot side piping would be made of stainless. For the stock motor pipes that join from the stock manifolds would be used.Built systems would have 1.5" Headers collecting just before the turbo.
Cold side piping will be 2.5" aluminum on the stock kits... 3" on the built kits.
These are rough plans as of now. I need to get my standalone first dialed in for the motor N/A then the turbo build will come shortly after... More or less I would like to know who has the resources and the intention of actually buying this? Otherwise I can simply make a one-off for myself and call it a day.
Old 06-04-2008, 02:21 PM
joe62890 joe62890 is offline
SVXless
I'm interested in this.
What are we looking at needing to have mod wise? I am assuming since you are going to be using a standalone management that a MT is going be to a must. Does the standalone support emission compliant components or will the car have to be modified to eliminate these components in order to allow the standalone to function properly.
Also out of curiosity, what kind of gains are we looking at HP/TQ wise, as well as, how many pounds of boost can a stock motor hold. How many pounds of boost can a motor built with the ECUTune components hold and how would using those in addition to the turbo effect the HP/TQ numbers and how many pounds of boost can be ran. If the gains with the ECUTune components as well as the turbo kit are a large jump over just the kit alone, what other parts would need to be upgraded? Drivetrain?
Sorry to bombard you with a million questions (some of them probably not very relevant) but I'm just a curious little monkey.
Old 06-04-2008, 02:32 PM
The kits would eliminate the EGR system, IRIS system, and purge control system. I am looking further into what it is going to take to keep the Auto but I have no definitive answer as of now.
Gains would more than likely be in the 50-60% range on a stock motor. This is mostly due to the fact that you are fighting a 10:1 compression ratio and they are going to be built to run pump gas. More than likely limited to 9-10 psi. I cannot tell you what the ECUtune engine will do. I personally am using the bottom end that I had from him and building my own heads using different valves, springs, retainers, and converting to bucket&shim for the lifters. This way I can choose my own cam profiles and not have to deal with hydraulic lifters. With the lower compression your gains can be much more substantial and fully expect over 100% gains.
I posted this to answer questions and yield interest in it. I may also need someone interested with an auto to lend me their car for an unknown period of time... but that is merely for trying to keep the auto with the new EM.
Old 06-04-2008, 02:40 PM
Myxalplyx's Avatar
Myxalplyx Myxalplyx is offline
XT6 is SVX's Daddy
Send a message via ICQ to Myxalplyx Send a message via AIM to Myxalplyx Send a message via Yahoo to Myxalplyx
Ahem! So.....the first initial kit would be free for the person lending you an SVX for an 'unknown' amount of time?
Kevin Thomas
1997 2.2ltr Subaru Impreza Outback Sport Wagon (AWD/Auto) 13.03@100mph
1989 2.7ltr Subaru XT6 (AWD/Auto) 15.912@85.93mph
1996 3.3ltr SVX (AWD/Auto) 15.070@91.38mph
***R.I.P***
2010 RAV4 AWD Sport (13.717 @ 99.19mph )
2015 Honda Fit LX CVT (15.2 @ 90mph)
Old 06-04-2008, 02:55 PM
SVXless
**** if that's the case I'm on my way.
Old 06-05-2008, 10:52 AM
Definately interested. How soon do you plan on offering these kits? In reference to the standalone, the feeling I got was that you would set it up but we would still have to get it properly/finely tuned by another party, is that correct?
