A/C belt removal
I just ascertained that my a/c belt was causing a smoking and high pitched noise. One, how do you remove this belt and put another one on. My air doesn't work hardly at all which is another issue so I hardly turn it on. Can I just cut this belt off and eliminate noise and burning rubber. Sorry I am so undereducated on this. This is a first in seven plus years with this car. Any knowledge will gladly be soaked in. Thanks.
Mike
95 Pearl Blue L |
Yes, you can just cut the belt off and all will be fine, But I'd recommend finding out what is wrong(Compressor or idler pulley) and actually fixing it. To remove and install another you simply loosen the 2 bolts you see at the A/C tensioner right under the A/C compressor and then grab the belt and pull and the tensioner will let the belt loose. simply install the new belt, Tighten the bolts almost all the way on the tensioner(leave them just loose enough to where it will move with a sharp blow but not move under the tension of the belt), and then use a screwdriver and hammer to move the tensioner to tighten the belt then finish tightening the tensioner bolts. |
Thanks Bud for the quick reply. I went right out and cut the belt off and put the alternator belt back on and drove it off with no problem. This problem started when I started hearing a grinding noise on and off. Then Fri. night it became a high pitched whistling sound and then the belt started to smoke. Idler pulley is turning OK with no binding so I guess its the compressor. Do you think failed bearings or are they're other possibilities? Take care and thanks for the help.
Mike
95 Pearl Blue L |
Jason |
Actually around three weeks ago I had my ac system checked at a dealer. They did have to add a little freon but otherwise all they're checks(when the car was idling in the shop) showed no problems. However out on the road the air will only get cold occasionally. Not good enough to stop the sweating. He wants me to leave the car with him for the day at 100 an hour and I never rescheduled a follow up. I will have my compressor checked out and get back to you if I need one. Thanks.
Mike
95 Pearl Blue L |
HAHAHA! That explains it all. They probably overcharged the system and it's killing your compressor and causing it to lock up. Take it somewhere else and have them check the pressure. |
After a second look today the pulley on the top(compressor) spins free with no hang-ups and the bottom pulley(idler?) doesn't move. Does this mean the compressor is ok and the idler pulley has maybe a bearing issue? I don't know if the idler pulley should spin freely or not. Please let me know if this means anything definitive or not.
Mike
95 Pearl Blue L |
