Old 02-02-2009, 04:41 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Temp Gauge may have killed my car
So I was driving along merrily, going about 55 and all of a sudden I notice my temp gauge go from normal to above red I freaked and pulled right over, and steam started to rise from the left side of the hood. Opened the hood, my reserve tank was boiling from the radiator venting.......and it did so for about 10 minutes. After I squeezed the upper hose to make sure the pressure had gone, I removed my cap to find the radiator almost full. So im like wtf..... either my thermostat didnt open.... or my water pump took a bleep right? So now im worried about my head gaskets..... if theyre toast.... I have to pull the engine to do them right? How hard is that for the SVX's? Im borrowing a block tester kit tomorrow to get the final verdict..... this is my only car so tomorrow is judgement day.
Old 02-02-2009, 05:16 PM
aust92pearl aust92pearl is offline
Re: Temp Gauge may have killed my car
that almost happened to my car driving home about 6 months ago but it was my heater core that blew then i pulled over before it hit red and saw my pas side floor soaking wet with a slight green tinge not fun had to drive around with no carpet for a week while it dried so now im heaterless but thats not so bad australia doesnt get that cold
Old 02-02-2009, 05:18 PM
liamrh's Avatar
liamrh liamrh is offline
blermostat
Old 02-02-2009, 05:54 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Update: Couldnt wait, so I walked the 2 miles to autozone and rented their block tester kit. Looks like the head gaskets are OK, but when I tried to start it again the car wanted to stall and it started smoking behind the timing cover So im going to be doing the water-pump yayyyy, and also the timing belt now...... This is fair warning to those who will ever in the future consider using Bars-Leaks..... it likes to chew up water pump bearings.
Old 02-02-2009, 06:32 PM
kwren's Avatar
kwren kwren is offline
Bars-Leaks... Just say no...
Keith
Old 02-02-2009, 06:48 PM
Hondasucks's Avatar
Subaru Technician
Trust me on this:
Get your water pump from the dealer. You will pay more than you will getting one from Autozone, but I've seen plenty of aftermarket pumps, even the "new" ones, come apart and take out the belt, t belt covers, etc...
While you are in there, check the timing belt, the cam and crank seals, and the belt tensioners and idlers, they are a lot easier to do while you have it apart doing the pump, also I would do the thermostat as well...
1986 VW Jetta
