Potential buyer - need advice
I'm looking at a 1996 SVX with about 103k miles. It's only had one owner, complete service records, and I've seen the carfax and it's all very good and seems to be well maintained. Is there anything specific, at this milage, I should ask about/look out for? This would be my first Subaru. I currently drive an '88 BMW 535is (avatar). Any pointers would be appreciated, thanks!
On a 96, check the rear wheel bearings. All SVXi seem to have issues with them. The early ones have tranny issues as well, but I think that was worked out by the 94 model year. Also, check the operation of the sunroof.
Here's what my SVX needed when I bought it @ <104,000: Radiator, AC hose, rear wheel bearings, PS return hose. The alternator and front half-shafts had recently been replaced. Within the first couple of years I needed a coolant temp sensor and crank pulley. With these items, mileage is more of a factor than model year. Good luck.
dcb |
Be sure to check the fluid levels, look around the engine bay and look for possible leaks. Wheel bearings, tranny, engine mounts, tranny mounts, suspention. Also be sure the front Llama guard is operational, royal pain to get replaced.
Llama guard?
..Make sure the muffler bearing is good..(seriously) Also make sure the wheels are on forwards, otherwise when you post pictures, everyoe will point out "Your wheels are on backwards" Slightly more serious checklist... -Matinence records are a BIG plus -Transmission:Though its a later year and should be alright, make sute it shifts smoothly, ect. -check all the fluids. oil, atf,and diff fluid are key -make sure theres no cracks in the windshield, its a very expensive part -Make sure there's no noise from the rear wheel bearings. Some svxi are fine, others are plauged by bearing problems -oil leaks: Valve cover gaskets and front seals. Fairly typical for a 10 yar old car, but will require replacing nonetheless -brake rotors may be warped -Check radiator top tank for cracks / leaks Also some more benign problems that are typical -Bad hood and trunk lifters -sunroof may need a light push to get it opening -check out for any excessive wear on the seats, steringwheel, ect. -paint may be faded / peeling from mirrors and plastic peices below rear windows Being you say its a one owner car with service recors, and well maintained...Id say all is well. Just check out them records and see if the timing belt and other 60k matinence was done
Have a look in the information folders in this particular How-To folder There is even a page on things to check when buying. Joe
Thanks guys, I've looked around this site and others a bit more. If I do end up buying I'll definitely be sticking around here!
Oh, one other thing I forgot to mention. If you do buy, you could do worse as preventative maintenance than to replace the timing belt. At 100K it's likely it's either never been replaced or it's been a while. Either way, replacing a timing belt is a relatively easy and relatively cheap way to ensure that things are running well.
Just my 2c... never had a timing belt break on an SVX, but I have had one break on a Honda. That wasn't pretty
Ich bin ein SVXer wieder My Rides: Red 1996 SVX LSi (Saffron) 2007 Yamaha FJR1300 (Kaitlin) Previously owned; green '95 L AWD (sold), black/pearlie '94 LSi (too many problems), Polo Green '96 SVX LSi (apparently notThe end of an era) Member #2 in the Yahoo! club, been here since the beta-testing days. In dire need of a cheaper hobby. |
