AWD Binding
Just got my transmission replaced with the 4.44 transmission and now my rear wheels bind when i take sharp turns. I am running a code for the rear speed sensor, but we checked its voltage and it appears to be working. Before the tranny replacement I recently lost my awd and it was just running in fwd; however, the wheels didnt bind when i turned..just didnt have the awd.
Any help? |
Re: AWD Binding
I would recommend approaching the shop that completed your swap, as that shoudl have been addressed prior to returning the car to you.
1991 SVX L JDM |
Re: AWD Binding
yes i have the blinking power light at start up...running a code 34? or 32? cant remember exactly...it was rear speed sensor code. They replaced the speed sensor to try and fix the problem and it didnt change anything.
Re: AWD Binding
The car is still at the shop...he is trying to figure out what the deal is. The cruise control worked before the swap..ill ask him when i talk to him to see if it works now.
How do I check to see if the transfer clutch is working properly? |
Re: AWD Binding
Sounds Like the transfer clutch solenoid. If you can get the actual code it would help. You can see if all 4 tires are spinning when it is on the lift. They may not all spin unless some gas is given.
98 Impreza 2.5RS Red 361K "Cherry Bomb" 99 Impreza 2.5RS Black 202K "Midnight" WRXed, SPT CAI, Perrin up pipe, Invida Divorced Down Pipe, cobb tune stage 2. 2013 BRZ on pre order... ---I miss my SVX... |
Re: AWD Binding
You did swap out the rear diff too...right?
