how hot is too hot??
Im finally finished with my engine swap putting the 3.3L into my 86 Vanagon - before yall hate the donor car was mostly junked -
im fine tuning the coolant system and its quite a doozey. the vanagon system is a sealed system - no radiator cap - and i think i might have a bad thermostat. if i have a bad thermostat i dont want to replace it until im absolutly positive its the problem im curious as to normal operating block temperatures for the svx. im planning on getting a laser thermometer to make sure i dont overheat the block while i test the system. so far its been getting what seems very hot very fast - my fears are that ive got an air bubble somewhere in the motor... |
Re: how hot is too hot??
I believe on the 3.0 H6 and maybe the 3.3 also there is a trick about raising the front of the car and running the motor to free a trapped air bubble when replacing the coolant.
Perhaps ask YT or OT.
Christian- 96 SVX Lsi #821, Bordeaux Pearl, 4.44 98 Legacy Trans, Trans Resistor Mod, Dakota Digital Trans Temp Gauge on A-Pillar Pod (awesome), B&M Trans Cooler in Driver's Wheel Well, External Spin-on Trans Filter, Synthetic Fluids in Trans and Diffs, 17x7.5 Primax 695 Rims, Alcyone Rear Panel, Svxfiles' 5000 k HIDs, Clear Headlights, "BOXER6" License Plate, Hard Wired Radar Detector, 94 Power Up Window Switch, Motor Resealed, new Coil Packs, new NGK Iridium Plugs, PVC Valve, Drilled and Slotted Rotors, Gloss Black Calipers and Rotors, EBC Greenstuff Pads, SS Brake Lines, Superb TomsSVX Cat Back Exhaust... SS Resonator, Flowmaster 80 Muffler, Magnaflow Quad SS Tips, Poly Swaybar Bushings, Endlink Mod, Rear Subframe Bushing Mod. Feels great and sounds even better. Thanks to AWD, LLC. 2003 Outback llb H6 3.0 Titanium Pearl- "BOXERR" Mostly Stock 1995 Bmw 325i Conv. Calypso Red- "RBOXER" Modest Mods 2004 Sea Doo Sportster 4-tec 15' Jet Boat, 1494cc, 1454#, 155 HP= <10#/HP Stock |
